battery connection
Old Jun 19, 2005 | 10:36 PM
bugdug97's Avatar
battery connection
My 2001 dodge diesel will not hold a charge to the batteries. I replaced the computer and both the batteries. I don't know what else it could be . I hope someone can help?
Old Jun 19, 2005 | 11:56 PM
Hemi Cat's Avatar
Check for the glove box light or under hood light being on. If you still can't find it, start pulling fuses and check for a current draw to find the circut and trace it from there.
Old Jun 20, 2005 | 06:37 AM
handymantim's Avatar
See if the charging system really is charging by checking the voltage at the batteries with the truck running. Should be somewhere around 14v plus or minus. If it's down around 12v or so then it probably ain't charging. If it's not charging then check to see if the A/C is working. If the A/C is also not working then you probably have a problem with your Crank Position Sensor.
Old Jun 20, 2005 | 07:09 AM
Geico266's Avatar
I'm with Heimcat. I have found that a couple of pennies in the gigar lighter can draw current and not pop the fuse. Start pulling fuses and look for a slight spark when you replace it and take it out quick. You'll find the circut, then look at everything in that circut.
BTW, check the lighters!
WesHawkins
18
May 11, 2020 07:41 PM
FishingFather
Sep 25, 2009 06:51 AM
KenC
Aug 13, 2009 04:08 PM
MLRey
Jan 17, 2008 07:42 AM
planejane
Aug 23, 2004 03:17 PM
