Barely Starts ???
Old Feb 15, 2006 | 04:17 PM
STACKED's Avatar
Question Barely Starts ???
Here lately my truck is takeing way ton many revolutins to start. Im talking about like 10. fuel pres. is at 16 psi at idle and low like 2 or 3 WOT. Is the low WOT pres. the problem.
Old Feb 15, 2006 | 04:52 PM
tmleadr03's Avatar
You shouldnt see less then 5psi WOT, if you do, get another lift pump.
Not certain if this alone would cause the hard start though, how are your batteries?
Old Feb 15, 2006 | 05:11 PM
STACKED's Avatar
They are fine it acts like a fuel problem. it acts like when you run out of diesel and you get air in the lines.
Old Feb 15, 2006 | 08:31 PM
farmer dave's Avatar
Have you checked for cracked or loose lines? Cracked lines are a common problem and things do come loose.
jetbt25
17
Aug 27, 2014 11:54 PM
CentralTXDodge
Feb 15, 2011 10:22 AM
97catintenn
Jan 7, 2010 11:33 PM
13ALPHA
16
Jun 6, 2009 06:17 PM
BigErksG2
Feb 19, 2009 08:49 PM
