Truck barely starts, HELP!!!
Old Feb 10, 2011 | 08:44 PM
CentralTXDodge's Avatar
Unhappy Truck barely starts, HELP!!!
Hi everyone. My truck started doing this a few weeks ago but it now has got alot worse. When I go to start my truck it barely turns over and sounds like when you have bad batteries. While it barely starts, it starts every time. I had the batteries tested, they where ok but I went ahead and bought new ones. The old ones where about 6 years old. I also cleaned the battery cables even though they where pretty clean. About two summers ago I installed a new starter because the old one just quit. It doesn't matter if its cold or hot outside, it still does this. Also, I can go for a long trip, stop at the store and get back in a few minutes later, go to start it up and the same thing happens. I really don't know what to look for and what to do. Also, maybe my truck has always done this and I haven't noticed but is the compressor suppose to kick off and on even when there are no heat/ac controls turned on? When this happens it makes my voltage drop big time and my interior/exterior lights all dim big time. Please HELP me.....it might be something simple and I just don't know what to do. Thanks in advance.
Old Feb 10, 2011 | 09:23 PM
cj360trider's Avatar
that click you are hearing is not your ac compressor...there are two solenoids under your drivers side battery. unplug 1 of the little wires on each and see what happens after that. sounds like your grid heaters are possibly screwing it up. have your Engine Coolant Temp sensor checked to see if the PCM is getting a proper reading
Old Feb 10, 2011 | 11:44 PM
rattlerbob5.9's Avatar
Sounds like burnt contacts in the starter it self. You can change these yourself and they are not expensive or that hard to do.
Could also be bad cables or connections
Old Feb 10, 2011 | 11:54 PM
Tate's Avatar
Sounds like your starter is on its way out. I had the same thing happen on my dually, the brushes were all worn out and arc marks were on the slip rings. Get a set of brushes and contacts and rebuild it.
The voltage drop is from your grid heaters, its normal for anything less than 20C/60F.
FYI, its the IAT sensor that trips the grids, not the coolant temp.
Old Feb 11, 2011 | 09:39 AM
blackimpala's Avatar
Was the new starter you put on a rebuild from a parts store? They are known for not lasting long. The diesel starter and gas starter are different but when the cores are rebuilt they all get shuffled together. I would get a set of contacts and try them.
https://www.dieseltruckresource.com/...d.php?t=141395
Floyd
Old Feb 13, 2011 | 09:49 PM
Was able to work on my truck this weekend. First, thanks for the help to everyone. It was my starter. The last one I replaced a few years ago, came with a lifetime warranty, so I went and got another free of charge. Installed and she started right up...so happy!
Old Feb 14, 2011 | 10:54 AM
ah yes tate you are correct i told him the wrong sensor thanx for catching that.
Old Feb 15, 2011 | 10:22 AM
infidel's Avatar
Don't be surprised if the new one doesn't last as long. Many people have been reporting that the auto parts "lifetime warranty" starters rarely make it even 10,000 miles.
Best to rebuild the OEM starter yourself or by a shop. Never give the OEM away as a core.
If you tire of replacing the lifetimer spend the extra money on an OEM.
jetbt25
17
Aug 27, 2014 11:54 PM
97catintenn
Jan 7, 2010 11:33 PM
13ALPHA
16
Jun 6, 2009 06:17 PM
BigErksG2
Feb 19, 2009 08:49 PM
STACKED
Feb 15, 2006 08:31 PM
