Auto tranny trouble
Old Jul 11, 2008 | 08:55 AM
Shootist's Avatar
Auto tranny trouble
My '99 CTD auto tranny started acting up the other day. Two problems occurred simaltaniou....together. Slow, or sluggish on takeoff and won't shift into OD. Played with button, shifter, rpm's, and checked fluid, but can't make it do anything different.
Is this indicative of any one thing? I don't have a lot of time to fix it and can't afford for it to be down very long, so It'd be nice to line up the suspect parts.
Thanks, Keith
Old Jul 11, 2008 | 10:31 AM
smokinram99's Avatar
It won't engaged only the OD? maybe the OD & TCC Solenoid.. it's easy to replace..
ROB
Old Jul 11, 2008 | 10:39 AM
Shootist's Avatar
I'd say it's something like that, only with the sluggish start, it seems more like a fluid problem. Maybe the torque converter. I don't know if this would keep it from shifting into OD though.
Keith
Old Jul 11, 2008 | 07:09 PM
bill50cal's Avatar
if the governor solenoid and transducer fails it can cause 3rd gear starts which will be real sluggish. with the shifter in N turn off engine, restart and shift to 1st and see what it does. if it starts off in low replace the electronics in the pan.
another test if you have a 0-100 PSI gauge it to check governor pressure.
bill
Old Jul 11, 2008 | 08:23 PM
dozer12216's Avatar
Yep! time to spend money on overhaul.
ridlangus123
Dec 30, 2013 08:36 PM
banks-powered
Dec 15, 2008 07:26 PM
frog
Aug 14, 2006 01:45 PM
betsycam
Jul 25, 2006 07:17 AM
ezdemon72
14
Jul 29, 2005 10:05 AM
