Auto to 6spd Manual Swap
Old Feb 1, 2010 | 02:13 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Hi Guys - I am considering swapping out my 47re for a NV5600. I know I need the tranny, bellhousing, adaptor plate, crossmember, clutch hydrulics, peddle assembly, clutch, drivelines, shifter, shifter boot and misc. plastics. And later down the road, things like manual steering colunm and gauge cluster. My first question is will my auto PCM work ok for now? Is the PCM something that can wait to be swapped down the road? 2nd question, will the transfercase from my 47re work with the NV5600?
Thanks is advance.............
Old Feb 1, 2010 | 09:02 PM
JPR Ram's Avatar
Really? No one has done this swap?
Old Feb 1, 2010 | 09:47 PM
t-boe's Avatar
I've been looking into this myself. The PCM will be fine. The transfer case needs a new input or a T-case from a manual. They're different splines (23 auto, 29 manual). I guess if you're doing a 100% swap, to make it just like it came from the factory with a 6 speed, a column and gauge cluster will be good, but it's not necessary. You can just remove the column shifter and put a piece of black plastic over the gear indicator.
Gas Sucks
17
Aug 2, 2009 11:45 PM
rambododge
Jan 21, 2006 04:01 AM
westport
Nov 24, 2005 01:43 AM
ezdemon72
14
Jul 29, 2005 10:05 AM
norsk
Jul 19, 2005 08:26 PM
