Atf Fluid
Old Dec 2, 2007 | 03:01 PM
MissionRam's Avatar
Atf Fluid
I was reading - Auto Transmissions Explained and it said that you can run hydraulic oil instead of ATF. I have a 2001 ram and it takes Mopar type 4.
What types of hydraulic oil can I run. TSO 10w or 30W, AW32 or 46? I think the oil is going to need friction modifiers. Any one use Hydraulic oil?
Old Dec 2, 2007 | 07:07 PM
Tazman's Avatar
MissionRam,
That just doesn't sound right.......
ftr
Old Dec 2, 2007 | 09:01 PM
MissionRam's Avatar
Here's the article
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Dec 2, 2007 | 09:09 PM
scottsjeeprolet's Avatar
so what's cheaper ATF+4 or a rebuilt trans?
I wouldn't take that chance and stick with the ATF.
Old Dec 3, 2007 | 08:57 AM
RowJ's Avatar
ATF is, by far, the most complicated blending formula of any vehicle lubricant. I would not pick that as a place to cut cost!
That being said... the only hydraulic fluid that would possible work is some brand of Tractor Hydraulic or Hy/Tran Fluid.
These fluids use to work well in older trannys but most only meet Dexron II specs and don't come close to ATF 4 requirements.
They will work but will shorten the life of your tranny and may not shift very well (never tried it and wouldn't advise it).
RJ
Old Dec 3, 2007 | 09:03 AM
RowJ's Avatar
Originally Posted by MissionRam
Wrong Link??
Old Dec 3, 2007 | 09:52 AM
glenn-k's Avatar
Gus at Farmboy's Diesel recommended Dexron MerconIII for my truck as I am always running heavy, put in a new converter and VB. He said it doesn't slip as much as the new fluid and woulld give solider shifts to keep from burning out clutches etc. I previously burned out the factory T/C lockup clutch-replaced T/C only per his recommendation. Worked great - saved thousands - still running strong at 12000 gross load on steep mountain roads.
Gus races 785 HP daily driver 2nd gen.
Old Dec 3, 2007 | 10:31 AM
JSPulliam21's Avatar
ATF is not a fluid I think you want to experiment with. ATF+4 is a synthetic, so just drain refill with that, and you will be good.
Old Dec 3, 2007 | 01:09 PM
Busboy's Avatar
My 2001 calls for ATF3 in the factory book. Topped up my xfr case last night after a leak at the drain plug.
Old Dec 3, 2007 | 01:22 PM
I guess I was mistaken. ATF+3 then.
Pig
23
Jun 4, 2010 01:01 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
Mslaughter
Aug 24, 2006 06:44 PM
Pig
Mar 13, 2006 09:12 PM
