APPS/VP44/47RE and queer electrons
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
I've recently noticed a number of posts dealing with problems relating to the mentioned items. I also have had problems relating to those items.
Here is what I've found. GROUND, GROUND, GROUND
With the use of digital electronics on the later model vehicles, little gremlins, AKA voltage spikes, will drive the electronic controls nuts. Insure your battery connections are CLEAN. Check ALL the ground leads coming off of everything electronic and clean them to ensure good metal to metal contact. Unless the spike is large or for a long duration, you cannot see them with a DVM. I ended up hooking a digital storage scope to the DC source and recorded the output over a 45 minute period. UGLY looking trace. All kinds of grass growing out of the flat line. Noise was very noticable in the 1100 - 1500 rpm range.
Spent a couple of hours yesterday afternoon cleaning ground AND B+ points. The problems I had went away and the truck runs like it has another 25 hp. Much smoother shifts and no gear hunting from the tranny. Overhead mpg indicates ~ a 1.7 mpg increase. Makes sense to me.
This public service message was brought to you by Shortround and the wonderful tools available in the Bat Cave.
ain'tlookinglikeanAPPSorIPanymoreShortround out
Thanks
