APPS Sensor
Old May 24, 2005 | 04:39 PM
CTD2001's Avatar
APPS Sensor
Does anyone now where this sensor is located? I think it is located under the throttle bracket, the bracket you remove to get to the Vp44 wire tap, Can someone confirm it? I have the code for that sensor, but when i was installing the comp i unplugged it and the negative battery cable touched one of the negative terminals and gave juice to the truck while the sensor was unplugged and i think that may have thrown the code. I tried the APPS reset procedure and the code is still there. On a side note, the truck seems to run just fine, Thanks for your help
Old May 24, 2005 | 05:52 PM
crobtex's Avatar
It's under the black linkage cover on the drivers side of the engine, right above VP44.
Old May 24, 2005 | 06:10 PM
CTD2001's Avatar
Yeah, thats were i thought it was, thanks for confirming that, do you know if unplugging it would set a code off? The reason i unplugged it was to be able to move the black cover out of the way better and i did not want to put to much stress on the connection
Old May 24, 2005 | 06:29 PM
crobtex's Avatar
I don't know about setting a code. The only time my cover was off was when I replaced the APPS.
supr
18
May 21, 2007 09:29 AM
gofastman
Feb 1, 2006 05:57 PM
jd4030
Jan 5, 2006 01:09 PM
calls
38
Jun 6, 2005 06:08 PM
tishmael
Aug 31, 2003 11:49 PM
