APPS reset!?! How is this done???
Old Jun 2, 2005 | 12:45 PM
PDXDodge's Avatar
How do you do an APPS reset?
Well like I said, I had this problem. I replaced the overflow, no dice. I can't swing the cost of a new pump, so I did the APPS reset (let it reset for over 2 hours). I then fired it up, and DISCO!!!! the problem is gone *knock on wood*.
Old Jun 2, 2005 | 01:42 PM
jthorpe's Avatar
DTR Founder
Click Here for DTR FAQ
Old Jun 2, 2005 | 01:57 PM
RowJ's Avatar
I agree with the quote above. In Step 4, I had two failed resets using the directions of 30 min. for the battery disconnect. I tried again, this time leaving the batterys unhooked for almost 2 hrs.......worked perfectly!
RJ
Old Jun 2, 2005 | 02:09 PM
Flatty's Avatar
I think that was me you quoted (the disco part gave that away). Do the APPS reset for AT LEAST 2 hours. Follow the directions to a T (That is what I did). I unhooked the batteries, and went to cook myself and my fiancee dinner. When we were done eating, I went out and finished it. Worked like a charm.
dIma
Old Jun 2, 2005 | 02:58 PM
PDXDodge's Avatar
Yes,
It was you (FLATTY) that I quoted. I didn't know how to highlight it the way others have. I have been getting stuck throttle and other symptoms. It sort of seems like a leaky injector at times then at others a stuck throttle. Maybe it is both with separate cures.
I have started another thread......i'm smokin please help to fully explain
supr
18
May 21, 2007 09:29 AM
mschultz77
40
Mar 19, 2006 09:27 AM
trex
16
Nov 14, 2005 09:45 AM
Luckycharm1
Sep 4, 2005 04:57 PM
MoreSmoke
Feb 14, 2004 08:51 PM
