Apps reset-Check engine
Old Feb 10, 2009 | 05:06 PM
kcccsryan's Avatar
Cool Apps reset-Check engine
Just reset the apps voltage to the amount written on the sensor .573,(disconnected ECM plug to get to wire). Now the check engine light is on. Ran the truck and every thing seems fine but the CHECK ENGINE light is still on. Do the codes need to be reset after changing the APPS voltage? Do you need to reset the apps(disconnect neg. battery procedure)? Can you clear the check engine code without purchasing a code monitor? Have only run the truck twice since voltage reset- Should it be run a few more times and see if it clears?
Thanks,
Kevin
Old Feb 10, 2009 | 11:58 PM
nickg's Avatar
did you have the key on when you disconnected the ecm harness? if so that will trip codes, I set my APPS voltage and I never triggered a code, have the codes pulled and cleared
Old Feb 11, 2009 | 09:11 AM
kcccsryan's Avatar
tripped codes
To be honest I cannot remember weather or not the truck was on during the procedure. On-off repeatedly.Thanks-that is probably what happened. Do I need to purchase a code monitor to clear the check engine light?( manual thinks so.) Better to just buy a tuner w/ code capability?
THANK YOU
Kevin
Old Feb 11, 2009 | 10:45 AM
PRG's Avatar
PRG
I just recently had an APPS problem with an accompanying check engine light. I reset the APPS according to the written procedure (disconnect batteries, wait for 1/2 hour, depress throttle slowly all the way and let up slowly, reconnect batteries) and the check engine light went out the next time I started the engine. I didn't need to reset the voltage this time. The truck runs fine now.
Old Feb 11, 2009 | 06:40 PM
kcccsryan's Avatar
Thanks ALL!!!!!!!!!!!!!!
Back to normal- no ck engine lt.
Keeping it between the lines --as fast as I can get away with.
Kevin
Canaminator
Nov 30, 2010 01:01 PM
supr
18
May 21, 2007 09:29 AM
Luckycharm1
Sep 4, 2005 04:57 PM
PDXDodge
Jun 2, 2005 02:58 PM
MoreSmoke
Feb 14, 2004 08:51 PM
