APPS reset
Old Jan 18, 2009 | 12:29 PM
jj3500's Avatar
APPS reset
I had trouble with my throttle response a few weeks ago. Actually was totally dead. I went to reset it...worked well for a while. Now I notice in 6th gear cruising, throttle response is getting progressively worse. It responds similar to my 1976 4barrel gas engine on a cold day. Is this eventually going to get worse and then shut down again. Like the first and only time it did? Or do I have to do another reset, which is what I have done, when I changed out my batteries only a few days ago.
Suggestions?
thanks
Old Jan 18, 2009 | 12:32 PM
mishkaya's Avatar
I would suggest a replacement APPS myself if that's what the problem is. Member Timbo01 here sells an aftermarket unit at a very reasonable price with fast shipping.
http://mopar.mopar1973man.com/tips/c...eplacement.htm
Good luck.
mishkaya
Old Jan 18, 2009 | 10:41 PM
Lockman's Avatar
Before I change the APPS I would check to see if the lift pump is actually working and if it isn't you have probably lost your IP also.
Your situation sounds just like the one I just went thru. I now have a new lift pump and injector pump.
Don
supr
18
May 21, 2007 09:29 AM
trex
16
Nov 14, 2005 09:45 AM
Luckycharm1
Sep 4, 2005 04:57 PM
PDXDodge
Jun 2, 2005 02:58 PM
MoreSmoke
Feb 14, 2004 08:51 PM
