01 starting problem
Old Nov 26, 2008 | 03:44 PM
m batterson's Avatar
01 starting problem
hi all,
a neighbor has an 01 2500.it will only start on level ground or pointing down hill.he has replaced the lift pump with a holy blue.this has been going on for several months.he is finally tired of it.
any thoughts?
mike
Old Nov 26, 2008 | 05:34 PM
Mike D's Avatar
Sounds like it's loosing prime. Could be the fuel canister in the tank. Just a guess.
Old Nov 26, 2008 | 07:12 PM
LITTLE_BIG_ME's Avatar
Could be a number of things could be an injector haveing a bad seal or could be bleading off a the water drain. Pressure the system up after it has be cleaned well, dried and look for a leak some where. Could be back flowing the pump also.
Old Nov 27, 2008 | 08:21 PM
10-95's Avatar
What fuel canister?
Old Nov 28, 2008 | 11:41 AM
johnh's Avatar
Originally Posted by m batterson
hi all,
any thoughts?
mike
check valve on VP44
Old Nov 29, 2008 | 05:14 PM
DODGERAM69's Avatar
I know this is going to sound weird but i put a post on here and somebody suggested that i should loosen my gas cap and now i have had no problems starting. i am waiting to get the new gas cap. apparently the gas cap is creating a vaccum. hope that helps.
Old Nov 29, 2008 | 05:17 PM
johnh's Avatar
cap is not a problem, the tank vent is plugged
Old Jan 18, 2009 | 07:45 PM
k5fan's Avatar
I had the same problem. Parked on an incline and tried to crank her and it acted like there was air in line. When I park on a flat surface the only problem I have is after start up she wants to die on me. Dont know what the deal is my solution was to stop parking on steep inclines and hit the accelarator after start up.
Old Jan 18, 2009 | 11:35 PM
BigIron70's Avatar
Cummins Guru
The tank has a vent sometimes gets plugged up with mud. If the bottom of tank is sucked up you definately have plugged vent. Also when removing cap after engine is shut down you will hear air rush into tank. Try cleaning the vent and putting hose on it to keep mud from getting in.
Old Jan 18, 2009 | 11:57 PM
nickg's Avatar
Fuel cap has a vent/vacuum valve as well, along with the tank vent.
The Fuel cap vacuum valve is seen as the black rubber flap (spring loaded circle thingy) on the under side of the cap, it can be depressed with a pencil or your key....trust me it can and will stick.
I usually suggest leaving the cap loose when someone complains of hard starts after sitting for a spell, or if it only seems to start when parked nose down hill. if you leave the cap loose and it starts later then there is a vacuum issue somewhere cap or vent, or a leak upstream of the tank that allows the tank vacuum to haul the fuel back to the tank. parking nose down hill makes it hard for the fuel to syphon back to the fuel tank
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Palmetto_kid
Apr 25, 2003 05:14 PM
turbospl311
15
Jan 21, 2003 12:39 PM
