Apps
Old Mar 1, 2006 | 08:42 PM
tmoore's Avatar
Apps
I have the code for low voltage to the apps. I am guessing that the reset procedure won't take care of it and I will need a new one. Does anyone know the p/n and or the price for the new throttle position sensor?
Thank you.
Old Mar 1, 2006 | 09:44 PM
piperca's Avatar
You need to list your truck and if it's an auto or not. You can try resetting the voltage. I have the instructions, so send me a PM with your email if you need them.
Old Mar 2, 2006 | 12:48 PM
blackdiesel's Avatar
Registered
had the same code swapped out the apps , and no diff. same problem ,turned out to be the ecm.
Old Mar 2, 2006 | 04:03 PM
Olratlr's Avatar
Thank you.
I don't know what year truck you have no profile but it will run you
any where from $330 to $430 -$430 being frrom Dealer. This was on a 2001
Old Mar 3, 2006 | 12:02 AM
piperca's Avatar
tmoore, you've got mail!
Ebay is the place for a replacement APPS ... new, just over $200!
Old Mar 3, 2006 | 04:51 PM
tmoore's Avatar
Thats a little more then I expected. I think its worth trying to reset it first. Doubt that will take care of it, but its worth a try.
piperca, never got the email. Can you try to resend it? I'll pm my email address again.
Thanks
Old Mar 5, 2006 | 06:27 AM
k9judge188's Avatar
bite the bullet
bite the bullet and replace it, you'll be glad you did, after multiple months of resets I finally replaced mine and the truck runs like it did the first day I bought it. I wish I had done it sooner. $450 was money well spent.
Old Mar 5, 2006 | 03:48 PM
Gene007's Avatar
k9judge, Just trying to clear up things in mind, When the apps is going out, is the only problem dead pedal or does the truck also run bad? Mine is running real bad and I suspect the Apps with the info I'm getting but most of the post talk mainly about dead pedal.
Regards,
Gene
Old Mar 9, 2006 | 04:52 AM
k9judge188's Avatar
Yes, mine ran like s__t when the apps was acting up. If you are showing "0122" as your code and nothing else, you have a bad apps. You can nurse it for a while with the reset but eventually it will be so bad your truck will hardly get out of its own way. If you have the money, replace it. That is really the only way to correct this problem. As a side note, I am appealing my repair bill to Dodge to have them consider extending the warranty on the APPS due to all the documented problems with it. Wish me luck.
Scubasteve
Feb 6, 2003 10:56 PM
BigBlackDodge
Jan 14, 2003 10:43 AM
BigBlackDodge
Jan 8, 2003 11:26 PM
TJinTX
Jan 7, 2003 08:19 AM
AlpineRAM
Jan 3, 2003 09:29 AM
