Another dumb question (KDP)
Old Dec 31, 2004 | 05:23 PM
No, I can't tell until the drill breaks through. The hole on the newer cases is blind, so the bit breaks through a little and then hits more metal.
edited for accuracy
Old Dec 31, 2004 | 09:42 PM
fschiola's Avatar
Dave, not to put too fine a point on it, but I haven't seen this repair done. When you find that you hit more metal, do you proceed with the repair as usual?
Old Dec 31, 2004 | 10:56 PM
Yes, you just put a set screw in to keep the oil on the inside. The screw ends up sticking out a little, which is a problem on some trucks because the fan hub interferes. In that case I pull the long screw and install a shorter one.
Old Jan 1, 2005 | 06:35 AM
ade's ram's Avatar
Well now i'm not sure how to interperit the info given. Wannadiesel when you say " the newer cases are not blind", exactly what do you mean by that, unless i'm not understanding what you mean, i thought that if you drilled through the case and then find you are still hitting more metal that meant the KDP had worked loose, and this in turn meant you had to remove the case so you can drive the pin back in, or have i missed something here....
Old Jan 1, 2005 | 07:11 AM
Sorry, I meant to say the hole on the newer case IS blind. That's what happens when you change the way you want to say something in mid-sentence.
The post will be edited to correct the mistake, sorry for the confusion.
Old Jan 1, 2005 | 12:02 PM
ade's ram's Avatar
Thanks for clearing that up............
Regards to all for new year from across the pond
Old Jan 1, 2005 | 12:24 PM
infidel's Avatar
Originally posted by Mike D
When I called Cummins tech support, they assured me that the ISB 24 valve engines weren't susceptible to the dowl pin failure
Tell that to my neighbor whose '99 pin came out and cracked the case. At least it was under warranty.
If you hit the pin when doing the jig repair you continue with the entire repair but just use a shorter bolt to keep the oil in till you have the time and parts to remove the cover. The normal length of bolt will stick out too far and the fan hub won't fit back on.
Out of the 50+ jig repairs I've done I've only hit a pin that was too far out twice.
Old Jan 3, 2005 | 08:45 PM
Fueling around's Avatar
I haven't done that many and found 1 pin sticking out. An old 90 with 200k on the clock had a pin in the hole. Tried to lever it back, but no go. Ended up grinding the threads off the bolt just past the case. Bolt cleared the pin and no oil leaks.
-John
Old Jan 4, 2005 | 04:09 PM
The jig from Harold does not have this problem, it comes in at an angle so you can use a pin punch and a hammer to knock the KDP back into its hidey hole. A nice side benefit is that the alternator doesn't have to come off.
Old Jan 4, 2005 | 04:25 PM
Mcmopar's Avatar
Mike D,
I did my KDP and it had worked out a bit. It's a 24 valve as you know. I did my Dad's 96 truck this weekend, it was out a bunch. His is the 12 Valve.
Old Jan 4, 2005 | 06:40 PM
infidel's Avatar
Dave, I've never used Harold's jigs, just the CPFF ones, since you don't have to remove the alternator does that mean you have to remove the fan cowl?
Old Jan 4, 2005 | 08:40 PM
The drill goes like this: Pop off the coolant overflow bottle, remove the clips from the top of the shroud, bust the fan loose, go bandage your knuckles. Remove the belt. Hold the shroud back with a bungee and remove the fan and fan hub. Remove the two timing cover bolts closest to the KDP and bolt the jig on. Put the air regulator on the dipstick tube. Drill, tap on the KDP with a hammer and punch to make sure it's in tight, tap the hole, clean with brake kleen. Smear the set screw with blue goo and install. Put the truck back together and you're done.
If I don't get too caught up in BS'ing with the owner I can do it in half an hour not including getting out the tools and putting them away. If you do a lot of these you ought to get a jig from Harold.
Old Jan 13, 2005 | 03:51 PM
Royal's Avatar
I wrote Cummin's about the KDP problem and the reply was sickening. Something like; "If a Cummin's/Dodge engine should fail within the one year warrantee period, repairs will be covered by your Dodge dealer." Cummin's said that this was a very minor problem and few if any cases had been noted. Ha ha.
Smokin96_12v
Oct 12, 2009 07:39 AM
93beater
Mar 4, 2007 10:56 PM
Krob
Mar 1, 2007 12:51 AM
Price_Dog
Aug 27, 2006 12:49 PM
Sawyer1
Jul 17, 2006 07:53 PM
