Alternator
Alternator
I am in need of a new Denso ALTERNATOR. about 200 for a rebuilt on. I see some new questionable brands on ebay. It there a high output one to buy? What should I do? were should I buy?
thanks
Dan
thanks
Dan
I have tried the Alterstart high output alternator on my truck, but with the high amp draw I have in winter months, intake grid heaters and snowplow hydraulic pump, that went south too.
I had the OEM Denso rebuilt at an alternator shop for $60. The brushes were fine, the diode plate is what fails in my case.
The best cost option may be finding a place that could rebuild your current unit, or doing it yourself. There are rebuild kits available, I believe Fostertruck.com has one.
Good luck!
Good luck!
same here, Find a local alt/starter rebuild shop, mine cost 20$ to fix, , I took it apart after hearing the alt making a growling noise. the brushes were wore out as well, was a cheap repair vs 250$ plus for a new one.
Typically the brushes wear out and can be replaced cheaply, and it takes but a couple minuits to check them.
http://www.fostertruck.com/alternators.htm
5.9Excursion
Mar 13, 2008 07:08 AM
