Alternative means of getting codes out of a '99 Dodge?
Old Mar 23, 2004 | 12:18 PM
Diesel-Dan's Avatar
Question Alternative means of getting codes out of a '99 Dodge?
We are tirng to get codes out of an otherwise dead in the water truck. It has the digital odometer and i did try the "crack the key 3 times" deal and did not work. I was wondering if there was another way of extracting the codes other than a scaner? We are pretty sure the pump is dead but need some better info to test our theory. Truck just cranks. Any suggestions would be appricated in helping diagnosis. Thanks in advance!
Dan
Old Mar 23, 2004 | 12:54 PM
Haulin_in_Dixie's Avatar
No way on the codes, only a scanner. Crack a line before the injection pump and see if the lift pump is supplying fuel. If so then crack an injector line at the head and see if the injection pump is supplying fuel to the injectors.
Old Mar 23, 2004 | 02:54 PM
Diesel-Dan's Avatar
That is exactly what we did. We ended up buying a cheep OBDII scanner anyway....we needed it bad! haha...we found NO pressure from lift pump to fuel filter at all. And the pump was real noisey. So we are going to try a lift pump and see what happends. Tank is fuel of RED! Ill post what we find....
Dan
Old Mar 23, 2004 | 03:21 PM
roadranger's Avatar
Well, since the lift pump has obviously been dead, the VP injection pump probably is too.
Once you change out the LP, if it still doesn't fire up, I'll bet it's the injection pump next.
Just think- all that money saved on buying red dye fuel can now be spent on a new VP-44!
Old Mar 23, 2004 | 03:27 PM
Mcmopar's Avatar
Are you guys sure that you cannot get the codes out with the key trick? I got one out of my wife's 2004 caravan that way.
Old Mar 23, 2004 | 04:33 PM
phox_mulder's Avatar
Not on a 99 Ram, doesn't work.
Works on 2000+ Dodges though.
phox
Old Mar 23, 2004 | 04:56 PM
Mcmopar's Avatar
Will it work on my 98?
Old Mar 23, 2004 | 05:13 PM
I'm pretty sure the 98 had another procedure.
Something like holding the trip reset in while turning the key on.
Not sure though.
phox
Old Mar 23, 2004 | 07:45 PM
firestorm's Avatar
Not sure though.
phox
I do know that holding the tripometer button in, while turning the key to the on position, sends the computer into a 'systems check'. At least on my '01.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
mrb321us
May 8, 2003 10:43 PM
c5r
Feb 3, 2003 05:20 PM
