alternative to cummins for lift pump?
Re:alternative to cummins for lift pump?
Carter made the lift pump on the 12v for Cummins. Jobber price for the 12v is $131.68 I don't think you will find it for less than jobber. If you are talking about the 24v in your sig Carter, AC ,and Airtex none list it.
I have a spare lift pump and it says Carter right on it. I also tried to purchase (from the dealer), before realizing how interchangeable these pumps are, a spare to carry with me. No way the dealer said. You must have a bad pump before we can get you another. I got sick of their BS and took off my new pump, and replaced it with two pushers (Holley Black / Carter). I love my Dealer, and I know that sounds strange, but they treat me well. I would definitely buy my next vehicle from them (regardless of price). You guys with bad pumps should explore the idea of a non-Cummins pump. Cheaper, and seems to run just as well.
WOW, I seem to learn a lot on this board, thanks for the replys!
Whiskey, good link..thank you !
Question about the Carter..will it mount in the stock location without too much modifying and where can I buy one for a spare? The one I ordered from Cummins in Louisville came in today but it will be tomorrow after work before I can install.
I ordered high flow banjos from Geno's and I think I'll put them on at the same time..is that a good idea? I wonder my odds of getting this thing to start afterwards. Wish me luck.
Larry
Larry
I've got the Holley Black in the factory location. The Carter is in the frame rails. I see 20 psi @ idle, 13 @ WOT (empty) and 8 with a load (recovers to 10 after a few seconds). It was higher before I got my transmission done. I am pushing way too much fuel, and not enough air. Maybe I need to take the SC Dieseltuner off until I can get a bigger turbo. The EGTs can hit 1600 quick!
[quote author=Mr.Matt link=board=4;threadid=17799;start=15#msg170024 date=1060363071]
The big Cummins dealer in Houston (Cummins Southern Plains) had 17 in stock at the time. $148 .
[/quote]
So that's where all of the lift pump's are at ;D When i go to the Cummins part's house here they have to get one from some where else as there are never any in Oregon >
[/quote]
You may want to look at www.wildcatdiesel.com for the fuel system upgrade they sell. I have it on mine I used to get 4 or less WOT now Im at 7 PSI + just from the kit about 1.5 hours to install and worth every penny.
I finally got mine changed this morning. It was easier than I had imagined and now I'm going to either carry a spare or go to Wildcat like Jamie said and get an upgrade. It took a first timer about half an hour and three different sized sockets to do it. Thanks for all the replys folks. I got 60+ K on this one so maybe just a spare stock replacement would work for me.
just took a peek @ wildcat's setup...look's like the way to go, where are you guys buying the holley pumps at and around how much?...i'm using a pusher pump now but im thinkin' of moving the stock LP in place of it and getting the holley, u guys are getting great FP readings...
ohhh yeah, and I installed some high flow banjos from Geno's while i was doing the pump and i have about 6 psi at WOT(subject to change as we all know
If I had to do it all again knowing what I know now I would have gone with the Carter kit in the frame rails in addition to the stock LP. Diesel Dynamics has a kit for the Cummins 24 valve that allows for use of a second LP in the frame rails. The "Kit" comes with 2 pieces of fuel hose, a relay the necessary wires, a fuse link and a bracket for mounting. I am not sure what they sell it for (retail), but I think it is still less money than the Holley. This scenario still gives the use of two fuel pumps, so if one dies you could still get to the destination. If the objective includes medium to severe mods, two pumps is the only way to go! LE
bluebull
Jan 23, 2005 11:34 PM
scottrod
Nov 30, 2003 08:50 PM
Monty
0
Aug 3, 2003 11:19 AM
