Lift Pump Alternative
Old Jan 24, 2005 | 12:38 PM
HappyGA's Avatar
Just curious if you guys think this would be a good lift pump alternative?
Have a look and let me know something..
Or give me your suggestions with link to it..
http://www.dieselmanor.com/fuel/preporator.asp
Old Jan 24, 2005 | 06:00 PM
BDR2500's Avatar
Worth the money, I have mine in the mail. Should be here any day now. I know a couple guys runnin it on their rig and they love it. The AirDog runs quiet, and you can fuel the truck when idling. The AirDog separates more air in high flow conditions and has a safety built in to protect against high pressure. It comes with 1/2 inch fuel lines from the tank to the engine, and it comes with everything to install and ready to bolt in. You get more with the AirDog in my opinion.
The Fass system is another lift pump solution, it's like the AirDog. Pretty much does the same thing as the AirDog. But the AirDog has more and does more.
Here's the link for thecompany that makes the AirDog:
http://www.ekstamworldwide.com/lighttruck.htm
The link for the FASS:
http://www.dieselpp.com/
Old Jan 24, 2005 | 09:05 PM
600 Megawatts's Avatar
Muted User
With all due respect, how could you tell this gentleman that its worth the money when its still in the mail on its way to you?
Kevin
Old Jan 24, 2005 | 10:38 PM
BDR2500's Avatar
Because of the guys I have talked to with it on their truck, and from what I have read.
Old Feb 5, 2005 | 10:22 PM
GIT-R-DONE's Avatar
FASS has worked great for me, been on a year and constant pressure and so far no problems.
Old Feb 7, 2005 | 10:24 AM
GIT-R-DONE's Avatar
Kevin, can you give me your opinion of the FASS system, and or the F1 Mach series injectors. I read in another post somewhere on here that you didn't like them for some reason. I am wondering why. Did you have a problem with them. Thanks
Old Feb 7, 2005 | 10:22 PM
F. Flack's Avatar
I checked out the links for the Fuel Preporator. Based on the information on the DieselManor web site, I wonder if the copyright lawsuit between Fuel Preporator and FASS (father and son) may be over -- there were several statements regarding the court findings. I also wonder if this has anything to do with the FASS II coming out as a "lift pump" only...
I installed the original FASS in my '99 last July, and really liked the improvement in puel pressure. However, I don't have anything to compare it to other than the three factory/OE lift pumps. I would like to hear from someone who has had the Preporator installed. Especially if they have other pumps/systems they can compare it to.
Franklin
bluebull
Jan 23, 2005 11:34 PM
scottrod
Nov 30, 2003 08:50 PM
LarryJ
28
Aug 8, 2003 09:51 PM
Monty
0
Aug 3, 2003 11:19 AM
