Reliable lift pump alternative
Anyone have an aftermarket fuel pump mounted in the stock location that is/has been working well for them.
Alas, my stocker is putting out lower and lower pressure. I will be ordering a -AN kit to replace my banjos in the meantime, but really want a better pump.
At one time P.E was the rage but after time problems developed. Anyone know if they recommend it for diesel yet?
Thanks,
S.C
Thanks,
S.C
Re:Reliable lift pump alternative
SC,
I have had a PE on and off my truck a few times, but the reliability hasn't been too impressive, yet. I just got my pump back again, and they have made a couple internal changes that are supposedly going to solve all the problems... we'll see. As for a different replacement, I'm now running a dual pump setup with -8 AN (1/2"
lines and fittings, and it's working pretty well. I've basically taken all the stock lines off, replaced them with the 1/2", and then installed a Holley Red (7psi, 97gph) back by the tank on a custom bracket to feed a "good" stock lift pump. At my HP level I can't get the pressure below 9 psi on a max WOT run, and it stays above ~13psi with the PMax off (DD TTPM and Supermentals only). It's whisper quiet and seems very reliable so far. You can get the pump for about $100 and the lines & fittings for about $150. I'm going to try the new PE to see, but I think I'll probably end up with this dual setup for good.
John
lines and fittings, and it's working pretty well. I've basically taken all the stock lines off, replaced them with the 1/2", and then installed a Holley Red (7psi, 97gph) back by the tank on a custom bracket to feed a "good" stock lift pump. At my HP level I can't get the pressure below 9 psi on a max WOT run, and it stays above ~13psi with the PMax off (DD TTPM and Supermentals only). It's whisper quiet and seems very reliable so far. You can get the pump for about $100 and the lines & fittings for about $150. I'm going to try the new PE to see, but I think I'll probably end up with this dual setup for good.John
I've had very good reliability with the Carter 4600 as a pusher for over a yaer and half and 40,000 miles. But then I also haven't had stock lift pump problems either.
I ordered it from Rod @ http://www.wildcatdiesel.com/
I comes with everything to go from your lift pump to injection pump.
bluebull
Jan 23, 2005 11:34 PM
Monty
0
Aug 3, 2003 11:19 AM
