Adding 2cycle oil to fuel ??
Old Sep 11, 2005 | 03:19 PM
rigby38's Avatar
A gentleman stop by today as I was taking the VP44 off to replace it he had a 99 also with 135000 miles on it I looked at it it has the original LP & VP on it he says he adds 1 qt of 2 cycle oil every tank full could he be on to something here or is he just lucky
Old Sep 11, 2005 | 03:41 PM
rockwithjason's Avatar
Oil is good! You can get the same results using ND30 and it's cheaper.
Old Sep 11, 2005 | 04:01 PM
infidel's Avatar
Most designed for diesel fuel additives add just as much lubricity as 2-cycle oil plus clean injectors and prevent cold weather gelling.
More bang for the buck using an additive.
Old Sep 11, 2005 | 04:50 PM
torquefan's Avatar
I agree. Anything with lubricity is better than nothing, but actual fuel additive yields the most benefits.
Old Sep 11, 2005 | 05:20 PM
rigby38's Avatar
I thought it made sence but the 2clye oil is made to mix with fuel & still lube His LP was still pulling 16 pds after 135000 miles & 6 years mine is 6years old but only 58000 miles most pulling a 38 ft race car trailer gros truck & trailer weight is 22000 by the way when I took my LP off yesterday I took it apart very easy to do there where sure a lot of wear on the vanes I took the vanes out turn them around it made 14 psi but the houseing is to scored up to trust just a learning curve here lol
Old Sep 11, 2005 | 05:21 PM
Tayloe08's Avatar
So is it a good idea to add fuel additives often? I have heard different but always thought it could not hurt just did not want to spend the money if it wasn't necessary.
Old Sep 11, 2005 | 05:24 PM
rigby38's Avatar
from what I have learned in the last 3 days you can bet I will be putting some kind of lube additive in my truck asap
Old Sep 11, 2005 | 05:41 PM
blackdiesel's Avatar
Registered
im running lucus fuel additive every tank now as of 4 or 5 tanks ago.
Old Sep 11, 2005 | 09:36 PM
mini14's Avatar
Cool
ive been putting 2 quarts of 2 cycle per tankfull for 3 years now, along with 16 oz. of power service. I record my mileage every fillup. Adding the 2 cycle has given me an extra 1.5 mpg. Have noticed through trial and error that 1 quart gave me no noticable increase in mpg. The truck has only had 5-7 psi fuel pressure for the past 70,000 miles with the original lift pump and vp.Edge ez was added 10,000 miles ago, and still not worried.I guess the extra cost of additives is slowely equalling the price of a new vp.
TEXAGS'98
May 30, 2008 08:40 AM
hopak
May 23, 2008 07:38 AM
valk
Jan 27, 2008 10:29 AM
thxman
18
May 30, 2007 11:25 PM
streetsmoker
Feb 10, 2006 07:49 PM
