Started using 2cycle oil/ pressure problem
Old May 22, 2008 | 03:46 PM
hopak's Avatar
Ran 2 cycle oil at 1/2 oz/gal with no problems. Upped the ratio to 1 oz/gal and the pressure gauge now shows a very slow 15 to 30 seconds rise to full pressure when starting. Once its up there it runs at normal pressure.
Normally the pressure rise is pretty much instantanous.
I have a new 7 micron filter.
Old May 22, 2008 | 05:35 PM
AggieJustin's Avatar
So if you make a WOT throttle run and the pressure pulls down, does it come down to normal levels or lower? And how fast does it recover?
I'd almost think that you have a clogged screen that might be slowing flow causing the slow pressure rise, but I'd expect to see lower pressures and slower recovery when fuel demand is high.
Old May 22, 2008 | 05:43 PM
hopak's Avatar
Idle is 8lbs; wot pull down 6 or 7 lbs. This is "normal and usual" for my truck. What is unusual is the slow build up to 8lbs when I start up. Usually the pressure jumps to 7 or 8 lbs immediately. I'm thinking I'll run to town and get a 10 micron fuel filter and some fresh fuel - see if that helps.
Old May 22, 2008 | 05:54 PM
wurkenman's Avatar
That little of 2 stroke will not have an effect on the flow mixed with the fuel. Just a coincidence I think.
Old May 23, 2008 | 07:38 AM
hopak's Avatar
Changed back to the old fuel filter and the pressure now jumps up on startup the way it used to! The only thing I can think of - I usually grind a couple of gaps in the top radius of the filter to let fuel get to the top where the pressure sensor is located - didn't do that and the filter fits pretty tightly in the Geno's filter housing cap.
So your right - not the 2 cycle oil.
Pineapple Kid
Apr 2, 2012 10:42 PM
TEXAGS'98
May 30, 2008 08:40 AM
valk
Jan 27, 2008 10:29 AM
streetsmoker
Feb 10, 2006 07:49 PM
rigby38
Sep 11, 2005 09:36 PM
