Acceleration Issues
Old Jun 28, 2007 | 11:27 AM
zimmstoy's Avatar
Acceleration Issues
Hey All,
I am having an acceleration issue with my 2000 Dodge Ram 3500 CTD 5 Speed. This issue I am about to explain occurs frequently once the truck gets warmed up.
Issue: While cruising down the road in either 3rd or 4th gear I lose throttle response at the gas pedal and the truck starts slowing down. It does not matter whether I push to the pedal to the floor or go up and down over and over again there is no response. Typically you would expect the truck to jerk around a bit when applying pedal and then lifting up. Again no response. When this is occuring i can put the transmission into neutral and then hit the gas and the engine revs up. I throw it back into gear and everything seems to be okay. Then it happens again. It is pretty annoying as I am sure you can imagine.
Background. Truck has 153k miles on it and appears to have been maintained at a mediocre level at best. Any advice you could offer would be much appreciated.
Old Jun 28, 2007 | 11:52 AM
thellums's Avatar
maybe dead pedal? Have you checked for codes?
Old Jun 28, 2007 | 11:54 AM
RowJ's Avatar
First off...Welcome to the DTR!
Sounds like the dredded Injector Pump failure is sneaking up on you! Could just be a defective APPS.
Go to Autozone, if you can and get codes read with their scanner!
Pray for no P0216 code! But I have to say your symptoms are textbook!
Good Luck
RJ
Old Jun 28, 2007 | 12:31 PM
blackdiesel's Avatar
Registered
two thousand, can check the codes with the key, trick on, off on, off, on and watch the odometer. should work
Old Jun 28, 2007 | 01:12 PM
RowJ's Avatar
"Key trick" won't work on a 2000. I believe it's only on 01's & newer!
RJ
Old Jun 28, 2007 | 01:15 PM
zimmstoy's Avatar
I will get the codes checked today after work and let you know what I find.
I assume that as long as 0216 doesn't show up signs would point to the APPS?
Old Jun 28, 2007 | 01:24 PM
RowJ's Avatar
Originally Posted by zimmstoy
..I assume that as long as 0216 doesn't show up signs would point to the APPS?
Not 100%! Have seen Inj Pump go out with no codes.... but not usually.
I would get a check on my fuel pressure, if you don't have a gauge! And I would get a fuel pressure gauge. The injector pump is a potential weak link on 24v CTD's and pressure should be monitored all the time.... looking for start of lower pressures!
Prices have come down over last yr. Mine was $1050.00 for a rebuilt. Runs great and has for 40,000 miles.
RJ
Old Jun 28, 2007 | 01:34 PM
zimmstoy's Avatar
Ouch. The prices on these puppies are awful.
Looking at 1050 rebuilt to 1500 from the dealer.
Is there any value to one of the BlueChip Diesel Special X units for 1900? Anything special going on in there?
Thanks,
Scott
Old Jun 28, 2007 | 03:26 PM
Registered
RJ
I don't have a 2000, but I've seen alot of post were they say it does work on it.
Old Jun 28, 2007 | 04:36 PM
johnh's Avatar
i have an 01, and the key trick only works to the point of 1693. when i get that code i have to get it read at autozone or checker.... so they changed sometime in 01
Old Jun 28, 2007 | 09:54 PM
zimmstoy's Avatar
Ok so the key trick worked and I got the following codes back.
P0463
P1492
P1687
P1693
So at this point (knock on wood) no p0216 code.
So how do you all think I should attack this?
Note: Truck was stock and had this issue. I added some upgrades last week while the truck was down including new turbo and 5" exhaust from turbo back. This may be causing some de-fueling since I have not selected a chip yet. However, the issue described above happened when the truck was all stock as well.
Any help/advice is greatly appreciated.
Old Jun 29, 2007 | 07:31 AM
RowJ's Avatar
Ok so the key trick worked. So at this point (knock on wood) no p0216 code.
Sorry.... Blackdiesel was right about key trick!
Upgrades you added will not make a defueling difference!
I would still go to Autozone. See what they get...usually more complete list of codes and they can clear them for you.
Than, if still driveable, I'd wait and see what, if any, codes come back.
Is it getting worse?
My understanding is all Bosch vp-44's out there are rebuilts... since they stopped making new a yr ago. Dealers prices around here for 'new' use to be over $2000 (when they were available) so I'm guessing your getting a rebuilt for the quoted $1500.
I believe all current rebuilts get the 'Fed Ex' electronics, so I see no big advantage to Blue Chip's product. JMO.
RJ
Old Jun 29, 2007 | 07:14 PM
rebal's Avatar
Thanks,
Scott
1900- 800 for a core . I just installed one and boy that truck runs nice. a bluechip pump is worth an extra 40+ hp .asI was told.
Old Jun 30, 2007 | 12:18 AM
ronnymcdonny's Avatar
My truck does the same thing but is an aoutomatic no codes though???
Old Jun 30, 2007 | 01:22 PM
zimmstoy's Avatar
So as luck would have it... No light, No code on the odo but good ol 0216 comes up on the scanner.
AHHHHHHHHHHH
