ABS Light / Brake Light / Speedometer
Old Nov 3, 2011 | 09:56 AM
Captum's Avatar
Question ABS Light / Brake Light / Speedometer
Good afternoon from a sunny and cold Newfoundland.
I have read through most of the threads regarding the ABS and Brake Light on.
I am leaning towards a damaged rear wheel speed sensor or the associated wiring. I will endeavour to test this circuit through the large plug on the CAB (controller antilock rakes) but do not know the resistance which should be encountered. I would like to know if this speed sensor is actually dead before ordering a new one.
Also probably associated, is that my speedometer only starts to register around 25 KM/Hr.
Any advice is greatly appreciated.
Old Nov 7, 2011 | 07:31 AM
VADSLRAM's Avatar
If the speedo is out also then it's the pumpkin sensor (was on mine) but if it's just the light then it could be the brake pedal switch. I broke mine diagnosing another problem.
Old Nov 7, 2011 | 02:27 PM
Captum's Avatar
Pumpkin Sensor??????
Thanks for the reply.
What do you mean by the "pumpkin" sensor?
Regards
Old Nov 7, 2011 | 03:50 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The Speed Sensor mounted at the top of the rear "Pumpkin".
Old Nov 7, 2011 | 05:57 PM
Captum's Avatar
Pumpkin
Very interesting terminology.
I will have to have a closer look at this sensor.
Best regards
Old Nov 8, 2011 | 04:05 PM
dukeraul84's Avatar
So, does this sensor off the tone ring send a 5v hall effect signal (square wave) to the speedo? I've been told all of the dodge speedo's run off this signal.
I am trying to come up with a way to run the stock speedo in my 92 ram off the diff, as the standard tranny/tcase I'm swapping in don't have a vehicle speed sensor adaptability.
Old Nov 10, 2011 | 08:57 PM
MidNight99's Avatar
Had the same problem, sensor fixed it.
Old Dec 6, 2011 | 04:18 PM
Captum's Avatar
Update
A week before I was scheduled to take the truck to the local mechanic to have the items fixed, all warning lights returned to normal and the speedometer is also again working . It is good to have a dark dash at night.
It is frustrating not knowing for sure what caused the problem in the first place.
Old Dec 6, 2011 | 05:50 PM
Mike L's Avatar
Don't remain. too optimistic that your problem has been resolved through magic smoke or anything else. I am pretty sure that they will return. My vote is still for the VSS at the rear diff or at least in the wiring of same which is prone to damage from dirt and water.
Good Luck and keep the forum posted if/when the problems do return.
Cheers!
Mike
Old Dec 25, 2011 | 12:49 PM
jethroish's Avatar
Last night I experienced similar problem. Please see my post. https://www.dieseltruckresource.com/...48#post3058048
Thanks
Old Jan 25, 2012 | 01:40 PM
frmr's Avatar
i have an issue my brake light an abs light is on but my speedo still works brakes are fine whats up
Old Jan 25, 2012 | 01:53 PM
jethroish's Avatar
frmr,
see the last post by me in this thread. May or may not help.
https://www.dieseltruckresource.com/...s-t298760.html
Old Jan 25, 2012 | 07:43 PM
novahauler's Avatar
frmr,
if you have 4x4 it also has 2 front wheel speed sensors. I had to replace driver side on mine.
BTW, it helps to have a mechanic friend to use an abs scanner to make sure which one if 4x4, b/c they are different depending on driver versus passenger.
Old May 1, 2012 | 01:04 PM
Captum's Avatar
Smile ABS / Brake Light Update
Good afternoon to all.
Just finished replacing rear pumpkin speed sensor. Both the ABS and brake light indicators in the dash are finally out.
When taking out the old sensor, the plastic cap broke off and that was the most diffiucult item to get out.
Thanks to all who left their comments which were much appreciated.
Rogers954
21
Jun 6, 2024 11:54 AM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
acoustic_axe
Jul 29, 2003 05:25 PM
