About to buy
Old Feb 12, 2010 | 08:52 AM
Cholmes's Avatar
About to buy
Hi, I am about to buy a 02 2500 truck with a Cummings of course and I kind of know the truck but still would like to know what I should look for. I know there is probably a million things but the cracked block thing worries me a little. How can I tell if this is a truck that may be suseptable to this or is there a specific place that this may happen that I can check?
Old Feb 12, 2010 | 08:56 AM
dozer12216's Avatar
Just above where oil pan bolts to block.
Old Feb 12, 2010 | 08:57 AM
Cholmes's Avatar
Right, left both sides? Is it obvious or hard to spot?
Old Feb 12, 2010 | 09:03 AM
2002-5.9's Avatar
Most commonly under the turbo just below the freeze plugs and above the oil pan rail. Search for "53 block" in this forum which appear to be more susceptible to cracking for more good info.
Old Feb 12, 2010 | 09:04 AM
wurkenman's Avatar
Welcome to the forum. Good luck with your purchase. Just a word of warning. The engine is a CUMMINS not cummings. These guys will castrate you in short order for the G. Let us know what you find with the truck and we want pics.
Terry
Old Feb 12, 2010 | 09:33 AM
Cholmes's Avatar
Ha Ha It was a slip of the finger! I think she is a good truck, Farm truck so kind of beat up but well maintained mechanically. 200K kilometers (120k mi) new rubber, brakes and Amsoil in everything. 6 speed and everything works. Needs a seat repair and a little paint and she will be good as new (well almost) Lots of power! lots and lots! Anyway I am getting for $7000 so the price is exceptional.
Old Feb 12, 2010 | 09:57 AM
rattlerbob5.9's Avatar
It must be a cannuk truck if it has 200 clicks on it
Check for history on the fuel system for lift pump and vp-44 injection pump replacement.
Check the current fuel pressure and for any codes the first thing you do after you get it home is PUT A FUEL PRESSURE GAUGE IN IT !
2wd or 4x4 ?
Old Feb 12, 2010 | 10:06 AM
sheriffav8r's Avatar
Take it to a shop and have them pull the DTCs (codes). Check the fuel pressure from the lift pump (the shop might be able to do this, too). Spray around the block/cylinder head gasket with a lot of brake cleaner and then run the engine and look for any fluid leaks. I wouldn't worry about a cracked block too much as these are HEAVY DUTY engines! Good luck, it sounds like a good deal....
Old Feb 12, 2010 | 01:26 PM
91r/t's Avatar
I thought the 2002 was free from worry of the 53 block? Didnt that phase out late 2000 and early 2001 production models?
Old Feb 13, 2010 | 09:38 AM
53 blocks were 2000 to early 2001 IIRC.
1980240D
13
Jun 11, 2007 10:03 AM
ABQFirefighter
17
Apr 18, 2007 05:40 PM
hemi_on
Oct 15, 2006 11:00 AM
BHD
Feb 9, 2006 04:28 PM
Badd Dogg Guy19
14
Apr 14, 2005 09:04 PM
