'99 Auto tranny problem
Old Aug 17, 2003 | 08:31 AM
MARKY MARK's Avatar
Truck is shifting out of lock-out too early. I think that's how you explain it :- It goes through the gears ok but when I hit about 40 mph it bogs down. Any help?
Old Aug 17, 2003 | 04:58 PM
MARKY MARK's Avatar
Re:'99 Auto tranny problem
Anybody have any ideas? ???
Old Aug 18, 2003 | 03:46 PM
MARKY MARK's Avatar
Anybody ???
Old Aug 18, 2003 | 08:08 PM
dan239's Avatar
Since no one else seems to want to talk to you, I will try to answer your question.
This shifting into overdrive and then TC lockup at just above 40 MPH is normal. Mine does the same thing. If you are pulling a load you can lock out the OD and TC until you are ready. This is what many drivers do to keep from lugging the engine with a load.
You can delay these shifts by speeding up more rapidly.
Hope this helps
Dan
Old Aug 18, 2003 | 09:12 PM
dcwm's Avatar
What RPM's does the tach. read when it's "bogged" down?
Old Aug 18, 2003 | 10:41 PM
MARKY MARK's Avatar
I'll check in the morning. It just doesn't seem right. It boggs down really bad.
Old Aug 19, 2003 | 06:51 AM
MARKY MARK's Avatar
It shift out of lock up(not sure if I got that right) at about 1500 rpms and drops down to 1000 to 1100 rpms. It's very irritating when I'm going up a hill unloaded > I have to practically floor it to get it to kick down to the right gear. It will do the same when I have 5,000 lbs. on the trailer.
Old Aug 19, 2003 | 04:37 PM
MARKY MARK's Avatar
I checked it again and it shifts out at about 35 to 40. I think that is way to slow for it to do that.
Old Aug 19, 2003 | 07:31 PM
dcwm's Avatar
From what you have discribed it sounds normal to me. Mine usually locks around 35-40 MPH and engine RPM will drop to around uumm....1200 or so and it does take a substantial amount of throttle to break the lock (or kick down).
When I started driving mine it took a lot of getting used to after driving snappy gassers that shift so much more and easier.
Personally I like how these trucks stay in gear (locked) even under load, helps fuel mileage.
Old Aug 20, 2003 | 07:58 AM
barracuda's Avatar
i agree, mine acts similar w/ lock-out...i never run in O/D unless im on the highway, much nicer around town when it locks out in 3rd gear instead of O/D..when mine is about to lock-up i will usually lighten the throttle pressure and let it lock up and gradually accelerate, i like this feature as u get more power w/ lock-up...just my .02
Old Sep 4, 2003 | 07:44 PM
chevota01's Avatar
My 99 auto went to the dealer to have the transmission shifting software reflashed. It now shifts 3-400 rpm higher, around 2000-2100 rpms. Just a thought.
Old Sep 5, 2003 | 08:54 AM
slayerfish's Avatar
My '99 used to shift just like yours does until I got the re-flash because of an erratic TCC problem.The TCC problem went away but the tranny shifts totally different now-upshifts are at ~2000 or 2200 now instead of 1700-1800 also TC locks up later than before40-45 instead of 30-35.One side effect is I've lost fuel mileage.
Diesel4blood
Jul 21, 2014 04:23 PM
zethtays
Nov 3, 2010 06:24 PM
lews930
Mar 7, 2007 06:33 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
