5600
Old May 27, 2004 | 03:56 AM
johnh's Avatar
Unhappy 5600
now that I have your attention, somebody tell me what`s wrong with my transmission, I shift from 4th to 5th & i get a grind
Old May 27, 2004 | 10:03 AM
thumper 549's Avatar
do we get more clues......new noise, new truck to you,? are ya tring to shift like a car??
Old May 27, 2004 | 12:38 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
try a three second count as you are shifting, very possible you are trying to go too fast remember this is a truck tranny not a car.
Old May 27, 2004 | 04:53 PM
dodgediesel4x4's Avatar
Does it happen even if you double clutch it? Some times when I'm in a hurry, I can get a grinding, so I always try and take it easy when shifting frrom 4th to 5th.
Old May 27, 2004 | 05:47 PM
phox_mulder's Avatar
If the fifth gear nut was starting to come off, would this cause the grinding?
Synchros wearing out?
Auto tranny guy here, just adding some possibilities into the mix.
phox
Old May 27, 2004 | 08:55 PM
Iron Horse's Avatar
You sure you are not moving the shift lever too far to the right and trying to force it into reverse by mistake? I did that a few times when i first got mine.
Old May 28, 2004 | 01:28 PM
ddestruel's Avatar
fifth gear nut isnt a problem, its a nv5600 since its an HO. I would suspect a possible minor lubrication problem holding up the transition or too quick of an attempt at shifting.
Try changing fluid to Redline MTL i had better luck with it than Amsoil for shifting smoothness in the nv5600. Also like i said try slowing down your shift, truck tranny cant force it in. 4th to 5th always grinds in every 6spd ive driving if im too fast on the shift.
1 last thought Could your clutch be getting loose? does it grind or fight you going into any other gears?
Old May 29, 2004 | 12:48 PM
johnh's Avatar
all other gears work fine. i bought the truck new. i think i know how to shift by now, i have redline mtl.... probably syncros are gone 113,000 miles
Old Jun 19, 2004 | 03:07 PM
johnh's Avatar
cost for repair was 1966.06 at six states
Old Jun 19, 2004 | 04:44 PM
Smokee's Avatar
...should have had an auto
Old Jun 19, 2004 | 06:08 PM
Hemi Dart's Avatar
Some info from Fritz's web page (dated now):
http://www.dodgeram.org/tech/transmi...600/update.htm
Old Jun 19, 2004 | 11:00 PM
johnh's Avatar
yeah, i think an auto would have been cheaper. but i like a standard.....it seems better than when it was new,,,, but then i`m useing redline mtl
Old Jun 21, 2004 | 06:22 PM
Sixpack's Avatar
Heck! That's only half the cost of a after market preformance slush box tranny!
Old Jun 22, 2004 | 11:15 AM
Gear Poet's Avatar
5600 is a super-strong tranny with weak synchros. For the '02 model year, NVG changed the materials used in the synchros to make them harder. 5600's should be driven like trucks, and a high-quality lube like Redline MTL should be used and changed out every 20-25K miles. An Eaton filter from Geno's Garage is extra insurance that has been recommended by the jobber that rebuilds NVG warranty claims.
txs
Jan 4, 2004 09:18 AM
prairieguy
Aug 21, 2003 10:07 AM
moparman2
Aug 2, 2003 11:15 AM
MonroeDiesel
Feb 20, 2003 05:56 AM
Superduty12v
22
Oct 11, 2002 07:42 PM
