47RE people
Old Aug 10, 2005 | 10:30 AM
PistolWhipt's Avatar
99 3500
82k miles +/-
daily driver, occasional heavy tows
Frequent fluid / filter changes and one time issue with bands out of adjustment ... no problems since. Decent tranny from a stock truck standpoint.
PISTOL
Old Aug 11, 2005 | 08:30 AM
SilverRam01's Avatar
01 2500
3.55 Auto
105,000
Just purchased a month ago. Mine does the same thing TEDHRS's truck does. (Have to help it into OD). Fluid / filter change and band adjustment last week. I plan on pulling a 28' stock trailer, 32' flatbed goosneck loaded down with round bales.
I've learned (via DTR board) that the tranny does shift nicer with the OD turned off up to about 50 mph. Doesnt seem to "hunt" as much.
Old Aug 11, 2005 | 08:31 AM
Mcmopar's Avatar
Put a shift kit in it!! SMR makes a real nice one.
Old Aug 11, 2005 | 09:52 AM
Mike D's Avatar
99 with 77,000 +/-
So far it's holding RV 275s and a MAD ECM. I do have a shift kit. The MAD ecm is pretty aggressive fuel wise, so I try to take it easy.
Old Aug 11, 2005 | 10:11 AM
chailey's Avatar
2000, 2500, 4.10, 174,000 miles.
I bought it used last November at 161,000 miles. The guy I bought it from said it was rebuilt under warranty at about 100,000 miles. He said occasional heavy towing, but mostly highway miles.
We serviced it at the first of the year (fluid, filter, bands, etc). I use it as a DD (very little towing). I think the TQ is slipping a little, but I have no big complaints so far.
I've got an EZ on the way, so we'll see how well it holds up to that and pretty heavy right foot...
Old May 7, 2006 | 08:42 PM
taken5875's Avatar
I've been mean to mine and can't seem to kill it. Slip it yes but it takes a licken and keeps on well you know the saying
Old May 7, 2006 | 08:49 PM
elandon1201's Avatar
57K no problems( then all the mods had what i thought was minimal slippage. Just put in an ATS Stage 5 with 5 star because the wife gave me permission. WOW much better now
Old May 7, 2006 | 09:54 PM
TMWeber's Avatar
02 2500 QC 4X4 LB
106,000 Miles
Bought 2 years ago with 54,00 miles. Previous owner towed a 5th wheel to Mexico a few times, and used it as a daily driver. I did fluid/filter change, band ajustment (due for another). No problems at all. I'm happy. (Daily driver for me).
Old May 8, 2006 | 03:44 AM
2500CTD's Avatar
2001 2500
116000
Mainly empty daily driver, but had to move and made 4 trips from AZ to OR then 1 trio from Or to FL, grossing from 18K up to 24K
Tranny started acting up by not shifting into second gear. only went into 2nd when cold. Got a new tranny and TC. MUCH better. Oh after the Smarty is when it started acting up.
Old May 8, 2006 | 04:36 AM
pizzaboy's Avatar
2000 2500 SB QC
daily driven, tow rig for the jeep- gets towed about 2 weekends a month
111000 miles, and the tranny sucks
apparently the transmission didnt like towing my jeep 1600 miles straight, last month.. now it doesnt like to shift out of first.. apparently ?clutches? are wearing out in TQ
now i need a rebuild
BUT MY EDIT JEEP TOOK IT ALL FIRST!
Old May 8, 2006 | 08:11 AM
BigBlue's Avatar
2001.5 2500 QC SB 4X4
100,200 miles
Daily driver
400hp
DTT Valve Body
Fluids been changed twice and filter once
No towing but lots of full throttle runs from 0-110mph and anything in between including frequent lock up switch use and heavy lugging.
It's just now starting to slip in OD with the comp turned all the way up. Normal driving with the comp on 1x2 doesn't seem to affect it to much.
Old May 8, 2006 | 04:28 PM
gcookieman's Avatar
Y2k 98,000
410 rear
4x4
pull 9000 # 5th wheel
regular fluid filter band adjust
no problems except BE SURE TO ADJUST TPS EVERY TIME YOU DISCONECT BAT CABLES THIS IS CRITICAL FOR PROPER LOCKUP AND SHIFTS.
Old May 9, 2006 | 08:23 AM
bglz42's Avatar
95k miles
3.55 rear
Tow HEAVY a lot...
No problems, just had tranny serviced. Everything looked great!
I got 217k miles out of my '96 CTD automatic, just by servicing every 20k miles. Still going strong for the new owner. I regularly towed heavy with that one, too...
Nothing wrong with Dodge trannies!
Old May 9, 2006 | 08:56 AM
hamilton71801's Avatar
01 2500 4x4
3.55
136,000
Tow #7700 TT and use it as a daily driver. Had a shutter when lugging it and found out that one of my VB bolts was laying in the pan. No problems now. I'm pretty easy on my stuff and a little **** about maintenance. When she does lay down, I will probably go with a Jasper since I can't afford a Goerend or DTT.
Old May 9, 2006 | 08:05 PM
AAmeeting's Avatar
01.5 3500 2wd
74,000 miles original filter and one fluid change
Drives good not great, Ive been in a truck with a built trans and wow its faster. Wish I had the money.
