47 RE won't come out of 1st
Old May 4, 2006 | 09:57 PM
RELH's Avatar
47RE won't come out of 1st
Can anyone help me here?
'01 2500 47re trans will not shift out of 1st unless I release the pedal above 2200rpm, let it decelerate, feel the shift then accelerate again. If I’m going up a hill at the decel/accel point it will hunt for 1st and 2nd. After it gets past the 2nd gear point it runs fine. Come to a stop and it won’t come out of 1st again.
Coasting around a corner it will act fine.
Has anyone experienced this? This just started yesterday, no problems before that.
What could it be?
Thanks in advance.
Old May 5, 2006 | 08:38 AM
J BODY's Avatar
And the bands were adjusted last when??? You could have dropped the anchor for the kickdown band. Drop the pan and check it out. Another possiblility is the the seal in the front clutch retainer is leaking bad.
Old May 5, 2006 | 03:37 PM
TORQUE's Avatar
Get scanned for codes with a good quality scanner, sounds like a bad governor solenoid, bands should be adjusted, and check tv cable as J BODY suggested.
Old May 6, 2006 | 03:44 AM
RELH's Avatar
Found the problem, it was the anchor, it was in the pan. Thanks. Any suggestion on a new transmission? I love my truck, but I don't trust this transmission, never have - never will.
Old May 6, 2006 | 07:16 PM
Mechanos's Avatar
How long have you had the truck? How many miles on it? Have you ever done any maintenance on the trans?
Don't go blaming the trans if you've never done any upkeep or maintenance on it.
Old May 7, 2006 | 01:44 PM
J BODY's Avatar
Drop the valve body, inspect the band. If no chunks of band in your pan, or the band is not burned black, reassemble the anchor and adjust the trans properly.
Old May 8, 2006 | 04:42 PM
pizzaboy's Avatar
haha.. that sounds like EXACLTY what my trans is doing right now... screw this, im dropping the pan!
PsychoRallye
Dec 16, 2011 04:45 PM
MrKen
Aug 1, 2009 04:34 PM
leonesm
Aug 13, 2007 09:15 AM
serious
Sep 13, 2006 08:00 AM
roughstock
Jul 31, 2006 04:24 PM
