2wd to 4wd
Since you don't have a C&C, no luck for you.
In you cab, do you have a lever to engage PTO where the normal Transfer Case lever would be? If so, you would have the dummy TC.
You probably have a 2WD trans then, still not terrible, the rear cases in cast iron are under 200 bucks on Ebay, and you really should do the mainshaft upgrade for the 5th gear nut, so it is a perfect time to convert your 2WD trans to 4WD. There was even a 241DHD TC on Ebay with the right 29 spline input for 650 bucks a couple day ago, might still be on there.
Jordan5687
Feb 18, 2009 02:48 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
