2nd VP44
Old Jun 16, 2004 | 07:37 PM
20014x4's Avatar
2nd VP44
Just got my truck back from the dealer. 2nd injector pump . I've only got 70000 miles on my truck. at this pace maybe i'll get 1 more before I'm out of warranty . dealer said fuel flow is good and pressure is good so they didn't replace lift pump. the way things are going this may be a very costly truck after its out of warranty. Their has to be some kind of fix to make the pump last longer than 35000miles. any ideas???????????????
Old Jun 16, 2004 | 08:41 PM
phox_mulder's Avatar
You probably just lucked out and got two bad pumps.
My original croaked with under 4,000 miles on it.
It was going bad for about 500 miles before it got bad enough for the dealership to see the signs.
Replacment has been going strong for 30K.
(pretty sure I got a reman, perhaps you got a new replacement?)
Best thing for the pump is good flow of lubricating and cooling diesel.
Change the filter often, perhaps throw in some additive to help lube things up every other tankful or more.
phox
Old Jun 16, 2004 | 08:52 PM
20014x4's Avatar
I always run PS and never let the fuel tank get below 1/2 tank.(good heat sink) heat kills VP's. change fuel filter every 5000 mi. rather it needs it or not. Thinking about F.A.S.S. system. is it worth the cost. right now I've got a holley blue I'm running on it. Just bought a fuel pressure gauge. probably install it this weekend. still glad I didn't get a ferd or G.M. product
Old Jun 16, 2004 | 11:36 PM
Pa outlaw's Avatar
what did your injection pumps do when they were bad?did they just quit or did they start acting like a bad apps sensor?everyone i know that had them go bad just died no warnings,any info will stick in my head,ive got my second one on my truck right now too but i also have a 190,000 on it
Old Jun 17, 2004 | 05:24 PM
All mine ever did was idle rough.
Anytime the RPM's got below 1,000 it sounded like it was missing.
Would almost die coming down offramps.
No codes, no APPS symptoms, never died completely.
phox
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
