2500 snow traction
"500 lbs in the bed over the axle". Even better than over the axle is as far back as possible. If you can get the 500 lbs a foot and a half behind the rear axle, not only will you have the extra 500lbs on the axle, you will also transfer some of the weight from the front axle to the rear axle.
Guest
Posts: n/a
Winter Traction
Live in the Snow Belt of NY. 1200# of sand back by the tail gate. Use a 2x8 to hold it there. I also air down to about 40-45psi. If I had 20# of pressure the rims would be destroyed.
Using Cooper M/S tires, I can go up almost all mountain passes without too much trouble. Truck remains balanced and has good control.
Without the weight, the truck will get stuck in <1" of snow.
Scott
Scott
Red3quarter
Dec 12, 2009 11:12 PM
Common
Mar 12, 2008 10:25 AM
