24v valve adjustment
Old Mar 6, 2004 | 08:55 PM
COLDHEART's Avatar
I have a 98 24v built in nov.97.I understand some of these motors have adjustable valves and some don't.How do I find out which I have?
Old Mar 6, 2004 | 09:11 PM
All 5.9 liter Cummins engines have adjustable valves.
Old Mar 7, 2004 | 09:51 AM
J BODY's Avatar
Yes, they all have adjustable valves, but the 24 valve has a different set up than the old 12 valve that doesn't require as frequent of service like the 12'er.
Old Mar 7, 2004 | 05:50 PM
thumper 549's Avatar
pc of cake to adj.- lot of us gear heads run them at minum listed specs with good results
Old Mar 7, 2004 | 07:08 PM
billg's Avatar
If you have the 98.5 you have the 24v. The service manual says the valves should be adjusted at 150,000 miles. I have heard of people getting a little performance kick by doing it earlier. Also doing as thumper 549 says and running them close to the minimum spec because Cummins sends them out a little loose from the factory.
If you don’t already have one it would be a good idea to get you a service manual. You can get one here, it will be money well spent even if you don’t do the work yourself you will know how it should be done: https://techauthority.gltghosting.co...atalogId=10051
Hope this helps.
Old Mar 8, 2004 | 06:55 PM
COLDHEART's Avatar
thanx for the replies.I DO have a factory service manual for this year,but it only showed the 12 valve adjustment,that is why I even questioned it.I can do it myself,but with this much great knowledge available (dtr members)I figured I would ask.
Old Mar 8, 2004 | 07:27 PM
COLDHEART's Avatar
thank billg,I went there and ordered the 24v.supplement
maxwell
Apr 10, 2015 06:03 PM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
storx
May 18, 2006 01:37 PM
Monty
Oct 18, 2003 12:35 PM
