24V owners should read good stuff
Old May 4, 2007 | 07:31 PM
mo.redneck's Avatar
Lightbulb 24V owners should read good stuff
This is From Chip at Blue Chips diesel, and sheds a new light on VP Failure. Just a thought, please feel free to add any information to this thread or debate what he says. I'd really like some opinions here.
BOSCH VP44 INJECTION PUMP AND LIFT PUMP FAILURES EXPLAINED
The best way to start this explanation is to quote an e-mail that was found on the Cummins website. “The Bosch VP44 has not been as reliable as we had hoped”. Depending on who you talk to and who you think is being honest, you will get only some of the information you need. I will endeavor here to get you up to date and informed; the reason I can tell you more is because Bosch has not, until recently, allowed any franchised dealer to service, dismantle or deal with the problems except to send defective pumps back to the manufacturing factory. Blue Chip has dismantled many pumps to figure them out and diagnose what failed and what caused the failure. We do not pretend to be any where near as smart as Bosch, but since there was no information and or truth out there, we felt we had to get the best information we could any way possible. It is this dismantling and learning process that allowed us to get a patent and a performance product to market.
The most common MECHANICAL problem with the VP44 pump is that the rotor seizes in the distributor section of the pump. I should note here that all previous rotary style pumps have had this potential problem, to varying degrees. The most common cause and most accepted reason for this failure on rotary pumps is lack of lubrication due to running out of fuel or the lower lubricity of the newer low sulphur fuels.
In the case of the VP44 it is more common for the rotor to seize in the distributor because the rotor was not "deburred" enough or correctly during manufacture. Under the higher working high pressure in the VP44 the edge of the slot in the rotor deflects and interferes with the distributor. Sooner or later the result is a galling of the two parts and then binding and then seizure. The seizure causes the "Drive Plate" to break and the truck stops running. There is less than a half a thousanth of an inch clearance between the two parts, so it doesn't take much to make the rotor interfere with the rotor. Pumps made recently ( since about 2000) are experiencing fewer of these kinds of failures, it seems to me.
The other reason injection pumps fail is electrical issues and failures. The computer on the top of the VP44 is susceptible to heat and heat cycles. The components on the circuit board develop bad connections over time and the result is hard start, poor perfromance, white smoke and driveability issues. Often these issues can be verified by codes set in the ECM.
A lot of people now know about bad lift pumps and think they are the cause of VP44 failures; NOT SO! Starting with the early 98’s, not only were they weak pressure wise, but also had exposed terminals on the bottom that corrode off in salt environments. The way to tell if you have a corrosion sensitive pump is to see if the electrical connection is a plug on a 6-inch pigtail coming from the bottom of the pump. If the plug is on the top cover of the pump you’re all set!
If the lift pump fails the truck stays running because there is another vane pump in the front of the injection pump, which keeps the fuel flowing AND THEREFORE LUBRICATION to the rotor. As long as there is return fuel flow from the injection pump there is lubrication to the rotor.The existence of the vane pump in the front of the VP44 is why these trucks keep running with a bad lift pump! The only accurate way to test a lift pump is to monitor pressure UNDER LOAD and if it is above 5 PSI, no performance is lost and the pump is OK. If pressure is less than this, a drastic reduction in horsepower can be felt, especially when pulling a trailer. The usual scenerio is a customer puts a performance box on his truck and the lift pump can't produce enough fuel to make more horsepower, and the performance product gets the blame.
Often people have said that increased pressure from add-on devices cause the failure. This statement only indicates their lack of knowledge, because, unlike most pumps, the VP44 pump does not create more fuel delivery by increasing pressure. The VP44 creates more fuel delivery by holding the fuel bypass solenoid closed longer. Fuel delivery pressure is controlled by the “pop off pressure “ of the injector.
The reason any aftermarket device that hooks up to the solenoid wire is blamed for the failure is that the failure 99 times out of 100 (honest numbers here) the pump fails within 20 minutes of running with power enhancement. The reason this happens is because the fuel solenoid is held closed longer, therefore using more length of the slot in the rotor. The slot in the rotor overlaps a hole in the distributor to allow for different timing and amounts of fuel to be delivered to the injector and when the solenoid holds the bypass solenoid closed longer, then the high “pop off” pressure is still there when the middle of the slot overlaps the hole. The middle of the slot is the weakest area and therefore deflects, interferes and seizes. Pump failure with fuel enhancement devices is not CAUSED by the enhancement device, but PRECIPITATED by the device. WE think this is a “glass half full” scenario rather than a “glass half empty” one, because the potential, eventual failure can be determined within controllable parameters, namely on the test run at higher power, close to home or the local dealer. The other side of the coin is, honestly, if your truck is still running 20 minutes after the installation you have a 90% chance your pump will last a reasonable length of time. Adding a power enhancement device that hooks to the solenoid wire can give you peace of mind that you can depend on the pump.
We at Blue Chip have invented a pump tester that hooks up to the same wires that we use for our performance products on the pump and can tell you in a very short time whether or not there are actual fuel signals going to the solenoid and therefore determining if the pump is working correctly. The only exception to this is if fuse number 9, in the fusebox on the left side if the dash, is blown; in other words, to diagnose a pump failure verify that fuse number nine is not blown and hook up our tester. Crank the engine and if the LED blinks you have a good pump; there are other rare kinds of pump problems, but if our tester says the pump is OK, the engine should at least idle and run. This is much easier and much less time consuming than either the Cummins tester or the DRB3 tool at the Dodge dealer.Our tester does not forecast life expectancy of the injection pump.
Lastly the installation of bigger injectors; do they alleviate the high pressure and therefore failures in the VP44? Absolutely NOT. They are a bigger hole so fuel volume is increased at the same pressure. Remember fuel pressure is controlled by “Pop off” pressure more than the size of the hole! Bigger injectors do get more fuel into the combustion chamber sooner, therefore giving the engine better throttle response.Bigger injectors are worth it but not for the reason of saving the pump.
Thanks for reading, Chip Fisher, owner of Blue Chip Diesel Performance
I found this on another web site.
Thanks Shawn
Old May 4, 2007 | 07:47 PM
yfz450guy's Avatar
good read!
so, how do we fix the pump reliability issues?
Old May 4, 2007 | 08:36 PM
Geico266's Avatar
Great info!
Great post!
Old May 4, 2007 | 09:00 PM
mo.redneck's Avatar
Well by the info that is in the artical is saying that bosch defects is the problem. Also in other info that i have found is to much fuel pressure upon start up is hard on the pumps. Required pressure should only be about 7 to 8 psi. So that way you dont overload the system while trying to start the engine/pump. So what i have done, IMO is add tranny fluid to my fuel, about a quart of ATF goes a long way, I have also noticed that milage has increased on my truck. The reason is I worked on a drill rig with an 8V92 Drip troit and found from trial and error that adding ATF or Hyd fluid made the injectors last longer, IE more hours per injector. But that is what I have found everone has their own ideas. Also by doing so it lubes the seal causeing longer life in that area also.
Old May 4, 2007 | 09:10 PM
yfz450guy's Avatar
Originally Posted by saab9k
Yes good read, is going to install a pusher pump next tank, pump on truck is on engine above started.
what the huh?
JHew84's Avatar
Originally Posted by yfz450guy
good read!
Kinda sounded to me like they are working on (or have finished and just not released yet) a redesigned VP44 that will last longer. Also sounds like they are standing behind 2000+ trucks being far less prone to failure (bosch probably redesigned the pump somewhat) so maybe upgrading to one of those could be considered a "fix"?
I think it would be beneficial to point Mr. Chip Fisher in the direction of this thread and get him to answer questions directly, might even be FAQ or sticky worthy if enough discussion gets generated! Definitly some good reading!
-James
Old May 4, 2007 | 09:23 PM
Ridiculous's Avatar
for sure good reading! i just got my new pump this weekend as a matter of fact and i will be putting it on tomorrow. hope all goes well and i hope to have MANY miles out of this one!!!
Old May 4, 2007 | 09:53 PM
Tate's Avatar
Thats right from Bluechips website. Its quite old, circa '04, I think. IMO, their pump isn't worth what they are asking. Stock rebuilds are the same as theirs. The newer electronics that they are using is the same as everyone else is using, and have been for atleast a year and a half. When my IP died on me in Nov. 05, I had it narrowed down between BC and a HRVP. You can see which one I ended up with. Same price, same electronics, same parts replaced, same warranty, but one actually gives a power increase.
Old May 5, 2007 | 12:20 PM
mo.redneck's Avatar
Tate i do agree with you, but i have a buddy at a dealer at cummins and he hooks me up at price they pay. Think about 150% mark up on all parts they get. So he is amost giving me a Vp 44 for free. 400$ still in box. Never opened. That is a brand New Bosch pump. So if you can make a buddy at a shop with a Dealers License your set. I was told that they are putting new electronics in them and also new parts internally so they will last longer. This is comming from a injection shop, so take it how you will.
Old May 5, 2007 | 01:24 PM
Sootin's Avatar
This original thread should deffinetly be added to the 24V tech articles/FAQ
king5335
26
Jan 17, 2010 07:57 PM
brendangsxr
Nov 21, 2006 04:40 PM
