2001dodge 4500 6speed lurching in neutral
Old 03-14-2019, 07:31 AM
Fordzilla's Avatar
Originally Posted by AlpineRAM
At the start of the problem it was just like the original poster described- idling in neutral, engine lugging down, vehicle trying to move. -
After all these years, I'm still learning...Ain't edjoomacation a wunnerful thing?...I have never seen a bearing that looked like that......Ben
Old 03-14-2019, 09:04 AM
KATOOM's Avatar
Agreed... I would have thought self destruction would take place almost immediately. Especially if the amount of drag was enough to attempt to push a 4 ton vehicle. Crazy...
Old 03-14-2019, 09:25 AM
nothingbutdarts's Avatar
Alpine, a customers transmission?????
Old 03-14-2019, 12:08 PM
AlpineRAM's Avatar
This is the tranny of my Volvo V70 D5 AWD. Self-destroyed after less than 100 k miles due to a small oil leak that was invisible due to the sound deadening material on the lower engine cover.
Since this exact model of transmission was no longer available as a spare, and changing to the successor would have needed new propshaft, rear diff, ABS and ESP controllers etc etc I decided to fix it and at the same time modify it a bit.
nothingbutdarts (03-14-2019)
Old 03-16-2019, 08:05 PM
SIXSLUG's Avatar
My original 5600 couldn't be torn down due to a galled bearing to the main shaft, shop said the 80 ton press they used wouldn't budge it so they gave up and replaced the whole thing....pretty sure it had gear oil in it at one time, not synchromesh fluid as req'd...Nice synopsis Alpine.
Old 03-18-2019, 04:22 AM
AlpineRAM's Avatar
Isn't friction welding awesome?
Old 03-23-2019, 12:58 PM
SIXSLUG's Avatar
It is while it was under warranty! The trans guy said the press started creaking so they backed off, he was afraid if it didn't grenade it may shoot across the shop or worse.....
fireguyfire
03-14-2018 09:54 AM
sqrl$$
21
11-04-2009 11:13 PM
v8440
04-10-2006 04:05 PM
Pickle
01-10-2004 06:19 PM
alleyyooper
16
11-15-2002 08:55 AM
Quick Reply: 2001dodge 4500 6speed lurching in neutral
