2001 automatic shifting problems
Old Mar 28, 2008 | 02:22 PM
Don Anderson's Avatar
I have a 2001 4x4 with automatic transmission with the plate on the side for a gearbox that is starting to develop some shifting problems and I hope someone has some good ideas for me. When I pull away from a stop light especially if I am turning to the left it acts like it is not in gear for a moment or two and then everything is fine. I drive the truck pretty gently especially since fuel prices have approached four bucks a gallon. The truck is bone stock and has around 135,000 miles on it. Thanks in advance for any help or suggestions.
Old Mar 28, 2008 | 02:30 PM
Fishin2Deep4U's Avatar
ATF is low.
Add a quart and it'll be fine. I am guessing as it's slipping. Check fluid hot in neutral on level ground and use the backside of the stick for the measurement. The front is not accurate.
If it only happens when cold, you are probably down half a quart.
Dave
Old Mar 28, 2008 | 02:40 PM
2001 automatic tranny
Thanks. This happens about five blocks from where I work. Have been pulling a trailer some in the evening and have not noticed any problems then.
Old Apr 2, 2008 | 10:47 PM
craig marshall's Avatar
I have the same problem did this fix your problem
Old Apr 3, 2008 | 04:11 PM
It did for a few days and I am needing to add fluid again so I have a leak somewhere. Weather we are having right now is not condusive to checking to see where the problem is.
ilmbg
Jun 21, 2009 02:33 AM
Mannie
Mar 18, 2007 09:30 AM
mchydro
Dec 26, 2005 07:49 AM
6foot9
Sep 13, 2005 08:40 AM
badmrb
May 21, 2005 11:42 PM
