2001 2500 5sp injection pump
Old Nov 29, 2006 | 01:03 PM
swordfish's Avatar
Angry 2001 2500 5sp injection pump
Hey guys...had my injection pump go out last night. Dealer says $2600.00 to replace. This is my first diesel so I was curious as to what is involved with install of a new injection and lift pump. Should I let the dealer do it or can it be done by a somewhat savy shady tree wrench turner. Also where could I get the parts to do the job (injection pump and transfer pump)? Thanks for the advice!!
swordfish
Old Nov 29, 2006 | 01:15 PM
Forrest Nearing's Avatar
DO NOT take it to a Dodge dealer!!!!!
at the very least, take it to Cummins. They'll do better work for less money. But they'll still be high priced. You can shade-tree an injection pump install.
Old Nov 29, 2006 | 01:21 PM
CTD NUT's Avatar
Removing and installing a VP44 can certainly be done by "a somewhat savy shady tree wrench turner".
Here are some excellent removal and install instructions here:
http://www.nwbombers.com/membersites/kent/vp44.html
Old Nov 29, 2006 | 03:06 PM
b4wheeler's Avatar
When I bought my Campaign pumps for my big line install, the pumps came with great instructions on how to R&R the injection pump.
Had it step by step and even had the size wrench needed for each step.
Old Nov 29, 2006 | 03:32 PM
swordfish's Avatar
B4wheeler where did you get your pump?
Old Nov 29, 2006 | 04:26 PM
P.J's Avatar
P.J
He is referring to a replacement LIFT pump, more than likely bought from a Cummins dealer (approx. $64.00).
There is a strong possibility, depending on how long you have been running with a bad lift pump (if indeed that is the issue) that just replacing it may do nothing at all.
They send a 5 or 6 page booklet with the "Campaign 504" lift pumps that detail replacing the Injection Pump. I assume this is because many times it has died as a result of the failed LP.
DON'T LET THE DEALER REPLACE YOUR PUMP(S). You can easily save around $750.00 by letting a Cummins dealer do it. Doing it yourself (or with a hand from someone) will be the cheapest way out. I would imagine if you did both pumps yourself you could get out for about $1,300 v.s almost $3,000 at a Dodge dealer.
Hope this helps.
Old Nov 29, 2006 | 05:26 PM
swordfish's Avatar
Can anyone tell me some reputable places to get an injection pump and transfer pump or does anyone know of a Cummins dealer around Charlotte, NC? Any suggestions of an internet source for these parts? Thanks
Old Nov 29, 2006 | 08:20 PM
mbfarms's Avatar
Deleted by request
Wide Open Diesel is in Asheville. Farmboys diesel is somewhere around statesville.
4969joes
Jan 14, 2012 11:00 AM
RR20012500
Sep 13, 2010 01:07 AM
granahan378
Jan 19, 2009 08:54 PM
Goober
Mar 12, 2007 11:35 AM
Dieseldog800
Sep 2, 2006 11:56 AM
