2000 5.9 stalled
Old Mar 10, 2016 | 05:04 PM
005.9newbie's Avatar
2000 5.9 stalled
My 2000 shutdown engine light came on won't restart. On side of road.
Old Mar 11, 2016 | 02:37 AM
BigIron70's Avatar
Cummins Guru
Is truck stock? Have fuel in tank? above 1/2, you can hear lift pump running when you bump starter? Crack fuel line open at injector, crank over engine any fuel coming out?
Old Mar 11, 2016 | 04:49 AM
Have not done a lot sitting on side of road. Yes could hear lift running, gauge reads just under half and the check engine light came on. Have ran out with 46 left to go now says 163. Hoping just out of gas
Old Mar 11, 2016 | 09:54 AM
patdaly's Avatar
Do the key on trick.
without turning engine over, cycle the key on, then off 3 times and then leave the key on. The codes should show down in the odometer window, let us know what codes are stored.
Could be simple, could be a dead IP, we don't know until we can see what code is thrown.
Old Mar 11, 2016 | 11:01 AM
P0460,p0645 and I am thinking p1643 maybe didn't have a pen have fuel cooking out of return line but can't get any at the injectors. Batteries died car won't supplies much. Might have to tow it.
Old Mar 11, 2016 | 04:57 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Moved so OP can get more replies
Old Mar 11, 2016 | 08:02 PM
SIXSLUG's Avatar
Out of fuel won't usually trigger check engine light....
Check into code identification and you will narrow it down....
Old Mar 12, 2016 | 06:05 PM
jrs_dodge_diesel's Avatar
0460 is the code for the fuel level sensor, so you may have a bad tank sensor. It's a somewhat common problem on our Rams.
Mine did it to me and it showed ¼ tank when it died/ran out of fuel. Would not restart until I filled the tank and re-primed the injector lines.
Old Mar 14, 2016 | 08:42 AM
patdaly's Avatar
Double check that last one, P1643 is a fuel circuit similar to the one jrs describes.
If it was P1693 then we are talking about a companion code that is stored in the ECM though, and that could be IP troubles.
Razorback Ram
Aug 26, 2009 12:55 AM
ticki2
Dec 4, 2004 03:26 PM
Gman77
Nov 22, 2004 03:25 AM
seanvu1
Jul 11, 2004 03:48 PM
Bo
Jan 11, 2003 08:32 PM
