Engine stalled-TST Flashing
Old Nov 21, 2004 | 09:42 PM
Gman77's Avatar
Went to back the truck in the driveway. Engine died. It started right back up and ran fine. Check eng light was on, and TST PM3 had all the lights flashing along with the number '8'. Unable to check for codes at home. FP is 14 at idle, 10 WOT. 1/2 tank of fuel. No symptoms before. Any ideas what is up?
Old Nov 22, 2004 | 12:39 AM
Barry Smith's Avatar
Solder your hot wire. Mine did the same thing everytime I hit a bump it would go off and then blink 8
Old Nov 22, 2004 | 03:11 AM
Gman77's Avatar
All connections are soldered.
Old Nov 22, 2004 | 03:25 AM
You've got a loose hot wire somewhere. Do you think you may have a cold soldered joint? The losing power and blinking has to be a hot wire. I would go over every connection if that doesn't get it I would send it back and have them check the box itself.
sgadd
Feb 6, 2010 07:41 AM
Hammily
Aug 8, 2007 07:18 PM
ticki2
Dec 4, 2004 03:26 PM
seanvu1
Jul 11, 2004 03:48 PM
