12 valve and 24 valve block difference
Old Nov 21, 2005 | 03:40 PM
rush47's Avatar
From: kandahar afghanistan for awhile, normally Tri-Cities Wa.
just wondering if 12 valve and 24 valve engine blocks are all the same minus the lift pump. I have the infamous 53 block, (with no leaks yet) thanks
Old Nov 21, 2005 | 04:59 PM
cummnz4x4pwr's Avatar
the blocks are the same everything is interchangaeable(head, pistons, lift pump, cams etc...) the only thing is that a 24v has different pistons because of the spray angle of the injectors, u can only use a 94 and up to do this because i believe that the 89-93 blocks are different not absolutely sure but i think so anyway
Jake
Old Nov 21, 2005 | 06:26 PM
Don M's Avatar
DTR Advertiser
The 53 block is not a good idea for serious performance use. If building a new engine, always shy away from the 53. Use a pre STORM 12 Valve or a post 53. The 54 and up is good.
The best choice is the Common Rail block, but not everything will interchange.
Don~
1generationkid
Nov 26, 2007 10:13 PM
Turbinator
Apr 11, 2007 10:56 AM
powerstrokin03
15
Oct 28, 2006 09:20 AM
akghound
Dec 30, 2005 08:34 PM
1320
May 17, 2003 03:28 PM
