108 degrees......and here come the VPs'!!
Old 05-17-2006, 01:00 AM
Ph4tty's Avatar
Originally Posted by need12v
Well looks like I'm gonna put off the SB Con FE till after the hot weather gets here, seeing as how I have the PO 216 and occasional miss. I've got the dodge warranty, but we shall see how that works out, I've got a feeling when they see the gauges they will balk. And with my holley pump system, I don't want them changing it to in-tank when they do the VP.
Put a carter pump in the place of the holly before taking it in. If you're running the oem pump I suspect the hassle factor would drop down a couple levels. I think the holly would cause more problems than the guages in the dealers eyes.
Old 05-17-2006, 07:52 AM
J BODY's Avatar
....and that depends totally on what "dealer eyes" are looking at it. If the wire isn't tapped and I can send the core back without a prob and it needs a pump, it's getting one.
Old 05-17-2006, 02:48 PM
CoastalDav's Avatar
I already found some wood.
My VP44 has 157 almost 158k on it. I have used additive for the past 4 years with each tank of fuel. Generally 8oz. Usually, 6oz of fuel additive and two oz of either tranny fluid or new 10w motor oil.
I tow alot in the summer down here when its 90+.
I think its necessary to run the additive. I think it also helps the LP. Only replaced one since I've had the truck (just found some more wood) at 95K.
Fingers Crossed Dave
Old 05-24-2006, 09:10 AM
Clunk's Avatar
Just keep the fuel tank on the full side and don't forget your additive.
Anybody check on fluid coolers this winter for cooling the fuel?
Old 05-26-2006, 09:35 PM
J BODY's Avatar
.....did FIVE vp's this week
Old 06-04-2006, 01:32 PM
sledcrusher02's Avatar
fuel coolers can be had through jegs or summit for under 60 bucks its been 80-90 degrees and my temps with fass and -8 lines and fuel cooler r at if not under ambient temps.
danalex
05-30-2011 03:42 PM
04ctd
04-25-2009 03:53 PM
Pack Mule
Competition / Pulls / OffRoad
04-27-2007 10:42 AM
abc4yew
15
08-18-2006 11:10 PM
BRUISER
08-16-2006 11:14 AM
Quick Reply: 108 degrees......and here come the VPs'!!
