0522 code
Old May 21, 2010 | 12:19 PM
RJW922's Avatar
0522 code
Lost my oil pressure gauge going to work last night, pulled the 0522 code for low input voltage. I dont have time to fix it today but need to drive 200 miles this weekend. I know it's not a pressure issue, but is it related to anything else that could leave me stranded?
Old May 21, 2010 | 12:25 PM
rebal's Avatar
if that's the only code no unless you have no oil pressure! plumb in to the system for a quick check,but is probably the sender
Old May 21, 2010 | 12:39 PM
RJW922's Avatar
When I left work last night the gauge was working for about a mile then it dropped to zero. It was reading close to 60psi before it dropped. Never has run that high. This morning when I drove it the reading was normal for a bit then started bouncing between 0 and 40 psi then dropped to zero. Only other code that is there is 0234 , but that has been around about a year.
Old May 21, 2010 | 01:23 PM
rebal's Avatar
let us know when you fix it what it was.
or if you need more help
ldornak
Jul 12, 2007 11:44 AM
Terraizer
Dec 14, 2005 03:56 PM
MR. T
0
Nov 5, 2005 11:58 AM
CTD NUT
Apr 5, 2005 04:45 PM
Ohio Joe
Nov 24, 2004 03:09 PM
