02 skipped a beat last weekend
Old Aug 6, 2008 | 08:06 PM
mo bowhunter's Avatar
Last weekend I was pulling a 25' gooseneck with a tractor and disc mower on, I wasn't for sure but I thought it dead pedaled once or twice but it was very brief. So I checked codes and came up with P 1693 and P 0216 and P 0234. One was fuel injector timing failure and one was turbo boost limit exceeded and one was DTC detected in PCM/ECM. Question is do I have real problems or was it the fact I was pulling 15000 lbs and in a hurry to get home?
Old Aug 6, 2008 | 09:24 PM
Red3quarter's Avatar
From what everyone says on this site the P 0216 is the Death Code for your injection pump. It could last a year or it going go out in a day depending on how bad it is. Mine lasted over 2 months with that code before I had it replaced. It was still strong when I had it replaced but I just didn't want to take any chances. If you are mechanically inclined and can replace it on your own look around here for some sites that see IP's at a good price, one that comes to mind is midwst fuel injection, MWFI.com. But if you are under warranty still like i was then just have the dealer replace it, it was one less thing I had to do at the time.
Old Aug 6, 2008 | 09:25 PM
nitrousn's Avatar
It sure sounds like a failing injection pump. Mine did about the same a few years back. I had a fuel pressure guage so when I did catch it acting up I was able to observe my fuel pressure which was ok. Do you have a guage??
Old Aug 6, 2008 | 10:30 PM
rebal's Avatar
0216 is not a good sign my vp44 went 44000miles more before it would not pull a load anymore and barely could get around check your lift pump pressure but me thinks the grave is close at hand
Old Aug 7, 2008 | 07:23 AM
I figured as much. It looks like I'll be looking for an injector pump. What do I do about the P 0234 code? I'll check the wastegate this weekend. Also with this truck being an automatic how much can I do to the motor before I need to start worring about the transmission? Keep in mind this truck sits all week and the only thing I use it for is around the farm. Most of the time I just use it to check cows, but it is used to haul hay, pull tractors around and cattle to the salebarn.
Old Aug 7, 2008 | 09:03 AM
RowJ's Avatar
Originally Posted by mo bowhunter
... What do I do about the P 0234 code? I'll check the wastegate this weekend. Also with this truck being an automatic how much can I do to the motor before I need to start worring about the transmission?
I wouldn't worry about an occasional over boost. Probably due to heavy towing. See if the code disappears after several starts.
You can add up to about 60 HP with no problems... on a healthy tranny. An EZ or a Smarty... both having boost foolers... will solve your code problem, give you more air and 'juice' the truck nicely.
I recommend the Smarty. More expensive but lots more features.
Sounds like when you tow...you tow fairly heavy. Keep it out of OD when heavy and watch closely for slipping converter (rpm increase w/ no speed increase). With good maintenance and frequent fluid & filter changes, the Dodge 47RE auto is better than many think. The after market rebuilts are spectacular.
RJ
Old Aug 7, 2008 | 09:56 AM
nitrousn's Avatar
So dont worry about a fuel pressure guage.
JBradley500
Sep 22, 2010 03:38 PM
zack birge
29
Sep 24, 2008 11:30 PM
timb
Jan 27, 2006 09:01 AM
jthorpe
Apr 24, 2005 09:18 PM
Gypsyman
Aug 27, 2004 04:32 PM
