01 gearing 3.54
Old Aug 6, 2008 | 05:46 PM
turbo246's Avatar
01 gearing 3.54
so on this 01 dodge i just bought it has 3.54 gears, i am very used to the 4.10's in my 12 valve, so it will take a while for me to get used to these gears and the difference in motors. but anyways i was lookin up the specs for speed and rpm ratio here http://dodgeram.org/tech/specs/axle/47auto.htm ... 4.10's are at 2100rpm on the highway and 3.54 are between 1700 and 1800rpm at 65. well the truck isnt registered yet but i have taken it down the road a few times, and it seems like at 65, its a hell of a lot closer to the 4.10 ratio. theres no way its at 1750 at 65, and i checked it with a GPS so the speedo is correct for the 245 tires on it. i just dont understand, it says it has the 3.54's in the glove box so it deff must have them gears. Say i hit the overdrive switch at 50 it will downshift and be revving to about 2100-2200 approx. idont know if its me or i just need to drive it more to see or what, it just seemed not to be right. any ideas?
Old Aug 6, 2008 | 06:54 PM
sleeper-sport's Avatar
I need to check but I'm defiitely below 2k while going 65, might be somewhere around 1800-1900. This is on both trucks w/3.54's, 99 2500 4x4 with 245's and a 98 3500 2wd with 235's.
Old Aug 6, 2008 | 07:02 PM
Smokeitup's Avatar
I beg to differ, In my 04 2wd with 4.10's I rev at 1900 at 65 mph, with the 3.54's you should be down around 1650-1700 rpm.
Old Aug 6, 2008 | 08:04 PM
koontzy00's Avatar
my 2000 5 speed with 3.54s at 2000 rpms 67mph my brothers 2002 with 6 speed and 4.10s at 2000 rpms 60mph
Old Aug 6, 2008 | 08:07 PM
koontzy00's Avatar
forgot to say that both trucks have stock tires 245s
Old Aug 7, 2008 | 12:20 AM
Zeus1987's Avatar
my 99 with 265s runs 2K @ 60 and about 2100-2150 @ 65
Old Aug 7, 2008 | 01:27 AM
Dinner's Avatar
With my 99, 3.54 Gearing and 47re Tranny. I run 110kmh at 2000rpm (about 68mph), probably around 1900 for 65mph
Smokeitup: You have the 48re tranny, the gearing might be different in it than the 47re tranny (just a thought by me).
Old Aug 7, 2008 | 01:31 AM
Cummins Freak's Avatar
yeah i run about 1950rpm's with my 4:10's at 65mph always have....now this is in my 12v with built auto
Old Aug 7, 2008 | 09:04 AM
sheriffav8r's Avatar
Did you check the tag on the diffs? The prior owner might have switched them out for something else....
Old Aug 7, 2008 | 01:42 PM
Checked it out last night and I'm exactly at 1800 while going 65mph. I'm not sure but in your case (48RE) might be a little different. I'm going to check my diff tag anyway just to make sure.
Carnage
Feb 19, 2004 09:56 PM
JKE
Sep 9, 2003 11:12 AM
faurotus
Apr 5, 2003 10:49 PM
malibu
Feb 18, 2003 07:21 AM
