3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
2008 mega cab dually tire questions
Old Jul 4, 2011 | 10:03 AM
ridlangus123's Avatar
10 Year Member
Hey guys i just joined DTR last night and have a few questions. i just bought a 2008 mega cab dually(my first dually) and have a few plans for it and was just looking for some ideas. I need new tires and want to go as big as i can with a 2" or 3" leveling kit. was wondering how big i could go and if i would need a spacer in the back, going ot be putting 17" rockstar rims or something of that nature. and any other ideas would be great thanks anything will help me out.
Old Jul 14, 2011 | 09:27 AM
SpeedyWS6's Avatar
37x12.5x17 on a stock suspension truck. 2" spacer out back.
Old Jul 14, 2011 | 07:14 PM
10 Year Member
thats an awsome truck! have a couple questions for you, do the front tires rub at all and if they do do you think a two in leveling kit would help? what kind of spacers did you get and where from and are those the stock rims?thanks for the pictures thats a sweet truck
Old Jul 14, 2011 | 08:01 PM
SpeedyWS6's Avatar
Thanks...
The fronts rubbed the inner fender slightly in some turns, but trimming the lower rear portion cleared that up. The rear inners required the corners that stick out being trimmed. Those are the stock wheels. It's hard to say about the leveling kit. The single wheel guys get away with it. I can't decide if I want a leveling kit or not as my trailers squat the truck pretty good. I got the spacers off eBay. They have been good so far.
Old Jul 14, 2011 | 08:34 PM
10 Year Member
sounds good one other thing those cooper stt tires your running are they load rating e or d and on your stock rims did u just take the rim inserts out and paint the rim or what did u do there
Old Jul 15, 2011 | 07:11 AM
SpeedyWS6's Avatar
They are d but the actual load rating is around 2500lbs each if I remember right. You won't find an e in a 37.
I just pulled off the simulators and put some gloss black on the stock wheels.
EDIT: The tires are rated at 3525 lbs each. Goodyear makes a 37 that is a d rated at over 4000 per tire.
Old Sep 13, 2011 | 06:14 PM
Patrolman808's Avatar
How do those 37's wear? My 35's did decent but not too great on the narrow rims.
Old Sep 13, 2011 | 06:35 PM
cbrahs's Avatar
sorry brother but both pro-comp (extreme AT) and Toyo MT are E rated tires and in a 37. had both of them on my last mega cab
Old Sep 15, 2011 | 10:05 PM
SpeedyWS6's Avatar
They weren't for 17's though were they? I should have been more clear.
Old Sep 15, 2011 | 10:11 PM
SpeedyWS6's Avatar
I have about 10k on the back tires, and about 1k on the front tires as they were just replaced after a guy pulled out in front of me. Comparing the tires the rears have about 25% wear. They should easily make it to 30k without being down to the last little bit. I run 50psi up front and 30 in the rears.
iflych52
Nov 6, 2011 11:19 PM
chancey
Nov 8, 2010 07:18 PM
mcolectd
Sep 19, 2010 08:46 PM
jimbo486
13
Nov 5, 2009 09:17 AM
StealthDiesel
17
Nov 7, 2007 07:35 PM
