work truck down
work truck down
I installed a raptor 150 on my 01 work truck. install went great but the truck loses its prime and bogs out and dies. to get the truck to start I have to bleed the injectors. is it possible its getting air in the system? all connections seem good. the pump runs for a second when the key is turned and then when you bump the starter it will run for about 5 seconds. Please help I need my work truck back on the road thanks...
Cummins Guru
Using stock pickup? Did you clean the screen on the pickup in tank? Are you using a relay to power the pump? Power and grounds are good? Using a test light do you have power to pump engine running or can you hear pump running?
I wasn't aware there was a screen, they is a relay built into the harness. It's hard to tell if the pump is running when the truck is on I will check with a test light. Once the truck is started it will bog out and die at idle but when you rev it up it won't die
CORed
09-20-2006 08:25 PM
usedtostrokeit
04-08-2004 12:45 AM
