Won't start.
Old Sep 1, 2009 | 05:07 PM
Dlowkes7's Avatar
Won't start.
So i got my cummins a few months ago, doing things here and there to get it road ready. I changed the fuel water filter, but when i did the threaded piece came with it. I think i put it on right, but i get a fuel drip every couple of minute or so. I have tried to start this beast several times, along with bleeding and finally unplugged the grid heater and gave it a slight mist of ether. It kicked over for a second or so then died. Is it just air in the system?
Old Sep 1, 2009 | 05:09 PM
comptz's Avatar
Have you checked the connection on the shut off solenoid?
Old Sep 1, 2009 | 05:10 PM
You are definitely getting air in there if it's dripping fuel.
Replace the fuel heater gasket.
And are you sure you put the fuel heater back right side up? I only ask because I've seen it done wrong...
Old Sep 1, 2009 | 05:15 PM
Dlowkes7's Avatar
Thats the think i am unsure of. I dont know if its upside down or right side up.
Old Sep 1, 2009 | 05:17 PM
Gasket side goes up. The gasket is a square cut o-ring that fits in a groove in the top surface of the heater. It's hard to tell it's even there when it's old and squashed down flat.
Old Sep 1, 2009 | 05:19 PM
Dlowkes7's Avatar
OK, is there a square washer on the filter side too? or just the bigger one on the filter. There is a small square one around the fitting on the bottom of the heater plate for me right now. Upside down?
Old Sep 1, 2009 | 05:24 PM
The little one on the spud is not important.
The square o-ring on the filter seals the filter to the fuel heater. There is another square o-ring in a groove on top of the fuel heater that seals the fuel heater to the head. Clear as mud?
Old Sep 1, 2009 | 05:28 PM
Dlowkes7's Avatar
yes Dave haha. clear as mud. i will let you know my findings
Old Sep 1, 2009 | 05:49 PM
Dlowkes7's Avatar
ok so the heater is right side up. but seem to be leaking from that area. should i replace the top gasket and see where that gets me?
Old Sep 1, 2009 | 05:52 PM
Yes.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
