wiring an alternator
Old Apr 29, 2007 | 02:20 PM
EClancy's Avatar
what do i need to do in order to bypass the "computer" when wiring in my alternator. i must need a voltage regulator, and other than that, i'm not sure. what terminals on the alternator need to see keyed power or something?
the reason i ask is b/c my alt is not charging the battery, but the alternator was put on a test stand and was putting out at least 14v. i think it would be easier just to make the alt work without having it go through the computer.
Old Apr 29, 2007 | 02:25 PM
KB440's Avatar
In the FAQ
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Apr 29, 2007 | 05:24 PM
EClancy's Avatar
when getting a voltage regulator, does it matter what kind?
what is the one is the above link reffered to as? i just wanna be sure i get the right thing
Old Apr 29, 2007 | 06:30 PM
The one in the write up is a standard Dodge regulator, same from the early '70's to the late '80's. Ask them for a regulator for an '85 D150, that'll get you the right one. Or go to the junkyard and pull a couple OEM ones off any old Mopar products. The OEM ones are better quality and you can get a spare to throw under the seat for less than one new one.
Old Apr 29, 2007 | 06:40 PM
EClancy's Avatar
just the info is was looking for...thanks
Puke
Aug 4, 2011 05:55 PM
7thMcD
Mar 29, 2011 09:41 PM
justdon
Sep 23, 2008 04:56 PM
5.9Excursion
Mar 13, 2008 07:08 AM
jimlj
Jun 15, 2007 11:18 PM
