Window interchangeability...
Old Jan 9, 2009 | 07:47 PM
TurboShadow's Avatar
So I broke my drivers side window this morning, and I need a new one. How old of a truck can I get a window out of and have it still work? My parts guy at work is saying 79. Im going to the JY to get a new one tomaro and would like to know.
thanks
Dustin
Old Jan 9, 2009 | 08:17 PM
Sounds about right. If it looks like the same door, the glass should work.
Old Jan 9, 2009 | 08:23 PM
kensmachine's Avatar
I was in a wrecking yard the other day and was told to look for 83-93 trucks Ken
Old Jan 9, 2009 | 08:39 PM
winkdemon's Avatar
If The Window In Your Truck Is Power And The Truck It Comes Out Of Is Power Yes . Or The Other Way Around Other Wise U Need To Pull The Metal Piece Off The Buttom Of The Glass, The Glass Is The Same. Just The Metal Track Is Different
Old Jan 9, 2009 | 10:09 PM
Its a manual. No frills here. I kept the bottom to take to the yard with me to make sure its the right one.
Old Jan 10, 2009 | 03:35 PM
kellypckp's Avatar
Vent window
Kind of the same problem. I have been told that 87 and new for the vent window. Will the other years work?
Old Jan 10, 2009 | 03:49 PM
Alwaysworking's Avatar
alwaysonDTR
if the truck has the same body lines the windows should be the same, so 80's-90's
70's are different vent windows, they have differnt latches
Old Jan 10, 2009 | 10:35 PM
Well, my truck is now sporting a 74 window. It fits! but its not a "bolt in". The rails on the bottom are diffrent and you must swap them. Which, is easier said then done. I got the 74 rail off the 74 window, and cleaned up the 90 rail. The problem was, the rubber between the glass and the rail was ruined on both pieces. So, I had to make a new one, and the rubber I had was much thicker so it took some tweaking. All worked out in the end, the window was the same shape.
The vent window is a different design on the 74, but looked like it would bolt into my 90 door. Actually, the doors I think would interchange with little effort. I think Im actually going to go back and get the STEEL door panels off that same truck and paint them black. Then I can ditch my worn plastic ones for some steel that wont ever go bad
1stgen1993
Aug 26, 2008 09:56 PM
spitfire9137
Aug 2, 2008 11:43 PM
1stgen1993
Jul 20, 2008 05:12 PM
BearKiller
Jul 3, 2007 09:09 PM
nickg
Jun 13, 2007 10:56 PM
