Will my '93 engine worh with my '92 harness?
Old Apr 11, 2008 | 09:05 PM
Trooperthorn's Avatar
Will my '93 engine work with my '92 harness?
I am planning to wire-up my ctd from a '93 w350. I have the engine harness out of a '92 w250 and the dash harness out of a '92 w250 and another out of a '92 w350. All ctds. Am I going to have problems with anything. I was thinking they would be the same. Thanks, Eric
Old Apr 11, 2008 | 09:23 PM
77machomopar's Avatar
i am sure they are the same. I dont see any differecne in the intercooled motors.
Old Apr 11, 2008 | 10:31 PM
Alwaysworking's Avatar
alwaysonDTR
if they are all intercooled no, non intercooled don't have the the crank shaft sencer for the tach.
Old Apr 11, 2008 | 11:40 PM
Thanks, that's what I thought, but I read something the other day about somebody worried about a pcm problem. What's a pcm by the way? I lost track of the glossary on this site.
Old Apr 11, 2008 | 11:48 PM
Fred Swanson's Avatar
92 and 93 PCM's and harness should be the same. I can tell you the 91.5 IC harness is different, as I have one of those and a 93. I used the 93 harness in the RCC.
92/93 has the integrated voltage regulator in the PCM, too. It has to have the crank trigger to make the alternator work too.
I adapted a 97 motor and engine devices to the 93 engine harness, it wasn't too bad.
Old Apr 11, 2008 | 11:58 PM
Your the guy I was talking about. Thanks for the reply. Eric
sleeperman
Jul 18, 2011 05:58 PM
cm979
Sep 3, 2008 08:23 PM
svtrich
Nov 17, 2007 06:33 PM
BHC
Nov 5, 2004 04:38 PM
