Difference In a 99CTD and 2002CTD engine harness
Old Sep 2, 2008 | 07:43 AM
cm979's Avatar
I have a 2002 CTD Engine I am going to replace mine with it, the new one has little over 100k on it. I know the Map sensor and a few others are different. My question is are there going to be any wiring or major problems sticking this motor in my truck. Or do I just use the 99 sensors on it and my harness???? Any advice would help thank.
Old Sep 2, 2008 | 09:22 PM
dozer12216's Avatar
My suggestion would be use your 99 wiring and ECM, PCM, and sensors. Have not researched but can just about guranteeeee something will be different. Or yes. The tranny control solenoids are different. The OH console is different. Some communication protocols are different. The VP44 is the same. Not sure about cam sensor/crank sensor and other sensors. Sell you left over components from 2002 for makeup.
Old Sep 3, 2008 | 09:04 AM
cm979's Avatar
well the motor out of the 2002 came from a base model the same as mine. I have a cam sensor and the crank sensor. the 2002 only has the cam. So I dont know if I should just use the 2002 harness,ecm and pcm??
Old Sep 3, 2008 | 08:23 PM
dozer12216's Avatar
Try the 2002 ECM, but afraid will run into communication protocol issues with other components. On swap like this, it seems as something is always different enough to really ruin your day. Sell 2002 engine and buy a 99!!!
JMHO
jeeptjstud
Competition / Pulls / OffRoad
57
May 7, 2006 05:58 PM
Flatty
Apr 19, 2005 10:09 PM
McGyver
15
Dec 1, 2004 11:15 PM
patriot pearl blue
Nov 18, 2003 11:03 PM
